11
The rsyslog module is showing up in system log /var/log/syslog as message repeated. rsyslog was also showing 99% cpu use in top at one point, possibly unrelated.
tail /var/log/syslog
Dec  1 22:18:16 here rsyslogd-2066: could not load module '/usr/lib/rsyslog/lmnsd_gtls.so', dlopen: /usr/lib/rsyslog/lmnsd_gtls.so: cannot open shared object file: No such file or directory
 [try http://www.rsyslog.com/e/2066 ]
Dec  1 22:18:56 here rsyslogd-2066: last message repeated 4 times
lsb_release -a
Description: Ubuntu 12.04.3 LTS Release: 12.04
sudo apt-cache showpkg rsyslog
Package: rsyslog Versions: 5.8.6-1ubuntu8.5
Related Question : How do I find that lmnsd_gtls.so is related to rsyslog-gnutls ?
here
  • 1,282
  • 18
Get the missing module by installing the rsyslog-gnutls package.
sudo apt-get install rsyslog-gnutls
see also http://virtuallyhyper.com/2013/06/install-splunk-and-send-logs-to-splunk-with-rsyslog-over-tcp-with-ssl/
see also http://help.papertrailapp.com/kb/configuration/encrypting-remote-syslog-with-tls-ssl
Check to see if the module file exists :
ls -la /usr/lib/rsyslog/lmnsd_gtls.so
here
  • 1,282
  • 18
This happened with me when I was trying to set up syslog with tls certificate similar to this. Rsyslog in few of the systems start as root and then fall to user syslog. There is a possibility that the certificate is not readable by the syslog user.
Check it using:
sudo -H -u syslog bash -l -c 'less <path to the certificate>'
if you get Permission Denied, add read permissions for your syslog user, and restart rsyslog.
Mohit
  • 111
-1
Dec 1 22:18:16 here rsyslogd-2066: could not load module '/usr/lib/rsyslog/lmnsd_gtls.so', dlopen: /usr/lib/rsyslog/lmnsd_gtls.so: cannot open shared object file: No such file or directory [try http://www.rsyslog.com/e/2066 ]
I have encountered recently above error, and the solution was to place certificates under /etc/rsyslog.d.
Reference: https://www.loggly.com/docs/rsyslog-tls-configuration/
