30
I tried playing videos in movie player but only the audio could be heard. I tried playing the video with dragon player but here also only the audio could be heard.
A message box appeared showing the following message:
Python (v2.7) requires to install plugins to play media files of the following type: H.264 decoder
I tried installing the plugin but it couldn't be installed. It isn't available in the software center too. How can I get this plugin?
bain
  • 12,200
sonakshi
  • 313
9 Answers9
37
In order to play H.264 encoded videos the corresponding decoder comes with the following library:
sudo apt install gstreamer1.0-libav
Kulfy
  • 18,154
Sebastian
  • 471
If you want the H.264 encoder, then
sudo apt-get install h264enc
will install H.264 in your system.
Malady
  • 292
Raja G
  • 105,327
  • 107
  • 262
  • 331
The package that fixed it for me on 16.04 is the gstreamer plugins bad. I got a message about Python-3.5 minimal wanting to install some MPEG-4 AAC plugin, which did not do anything. To fix: In a terminal type:
sudo apt-get install gstreamer1.0-plugins-bad
If you still can't get it to work somehow, you can try VLC as a workaround, installable by:
sudo apt-get install vlc
I did not unclick the restricted software, that may work but may disable other codecs. By the way, movie player or Video is the Totem video player.
I think this is part of the package gstreamer-plugins-bad. If you search for this in Software Center it should show up. It might be that you have to activate the multiverse repository (start Software & Sources and tick the appropriate box for this).
After you have installed the package, Movie Player should be able to play the file.
fohswe
  • 546
The audio-only gstreamer bug can easily be resolved
Hearing only audio on H.264 playback with an otherwise black video screen was reported as gstreamer1.0 bug #1562875.
Luckily, this bug can easily be resolved by issuing the following command once:
$ rm -R ~/.cache/gstreamer-1.0
This will take effect after restarting the application.
Serge Stroobandt
  • 5,719
  • 54
  • 59
Installing gstreamer0.10-ffmpeg from a PPA as described below solved this for me.
sudo add-apt-repository ppa:mc3man/trusty-media
sudo apt-get update
sudo apt-get install gstreamer0.10-ffmpeg
A.B.
  • 92,125
Ibungo
  • 250
Easiest thing you can do is Download & Install VLC layer from Ubuntu Software and enjoy your vedioenter image description here Install VLC player [1]: https://i.sstatic.net/hrKWg.png Open With VLC Player [2]: https://i.sstatic.net/k6vpE.png Enjoy [3]: https://i.sstatic.net/Kzg5d.png
I had the same problem with playing videos. Video player wanted to download mpeg - 4 acc decoder and h.264 decoder, but this hadn`t happened due to legal reasons (-if I understand correctly what was written in the window what appears after pc was trying to download mentioned programs).
After I unclicked Software & updates -> Ubuntu software -> "unclick" Software restricted by copyright or legal issues (multiverse) all start working again. (I mean that after this operation pc downloads what he needed and that it started working).
Following this video (https://www.youtube.com/watch?v=Vk5viMViSXk) worked for me. Now, I am able to play and seek forward/backward h264 files created by my Chinese IP Camera.
To sum up:
  • Open VLC.
  • Go to: Tools/Preferences. Select Show settings: `All'
  • In Input / Codecs / Demuxers, select Demux module as h264 video demuxer. Save and restart VLC.
Now you should be able to play h264 file.
Hieu
  • 409
