SOLVED!!! Jan 1, 2014. (see last edit)
The motherboard on my win PC blew the PCI-EX slot, so I had to swap it to my Ubuntu box. Everything works fine except the NIC. I keep getting a cable unplugged message. The NIC works fine in Win XP ( Dual Boot setup) so it is not hardware related. Ubuntu 12.04 does not "see the OnBoard NIC Marvell 88E8056.
I have downloaded and installed the sk98lin driver module from Marvel. It shows up as a kernel module. but Ubuntu keeps loading the old sky2 driver module. I have tried "Blacklisting" the sky2 module but it keeps loading it.
Here are relevant terminal outputs:
hans@hans-GA-78LMT-S2P:~$ lspci -k | grep -A5 Ethernet
02:00.0 Ethernet controller: Marvell Technology Group Ltd. 88E8056 PCI-E Gigabit Ethernet Controller (rev 20)
Subsystem: Foxconn International, Inc. Device 0e0a
Kernel driver in use: sky2
Kernel modules: sk98lin, sky2
hans@hans-GA-78LMT-S2P:~$ ifconfig -a
eth1 Link encap:Ethernet HWaddr 00:1c:25:51:24:43
inet6 addr: fe80::21c:25ff:fe51:2443/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:304 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:0 (0.0 B) TX bytes:69952 (69.9 KB)
Interrupt:19
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:16436 Metric:1
RX packets:168 errors:0 dropped:0 overruns:0 frame:0
TX packets:168 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:13344 (13.3 KB) TX bytes:13344 (13.3 KB)
Does anyone have a solution to the problem? If so, Please be specific and clear, please. I have been around computers for a long time ( remember punchcards?) but am a real NOOB at Linux type systems.
Requested info:
Here is the content of the 70 persistent-net rules file :
# This file was automatically generated by the /lib/udev/write_net_rules
# program, run by the persistent-net-generator.rules rules file.
# You can modify it, as long as you keep each rule on a single
# line, and change only the value of the NAME= key.
PCI device 0x1969:/sys/devices/pci0000:00/0000:00:06.0/0000:02:00.0 (atl1c)
#SUBSYSTEM=="net", ACTION=="add", DRIVERS=="?", ATTR{address}=="90:2b:34:ad:c3:22", ATTR{dev_id}=="0x0", ATTR{type}=="1", KERNEL=="eth", NAME="eth0"
PCI device 0x11ab:/sys/devices/pci0000:00/0000:00:07.0/0000:02:00.0 (sky2)
#SUBSYSTEM=="net", ACTION=="add", DRIVERS=="?", ATTR{address}=="00:1c:25:51:24:43", ATTR{dev_id}=="0x0", ATTR{type}=="1", KERNEL=="eth", NAME="eth1"
PCI device 0x11ab:/sys/devices/pci0000:00/0000:00:07.0/0000:02:00.0 (sk98lin)
SUBSYSTEM=="net", ACTION=="add", DRIVERS=="sk98lin", ATTR{address}=="00:1c:25:51:24:43", ATTR{dev_id}=="0x0", ATTR{type}=="1", KERNEL=="eth*", NAME="eth0"
Extra output asked for:
Newly auto-generated 70-persistant-net.rules file after deleting the old:
SUBSYSTEM=="net", ACTION=="add", DRIVERS=="?", ATTR{address}=="00:1c:25:51:24:43", ATTR{dev_id}=="0x0", ATTR{type}=="1", KERNEL=="eth", NAME="eth0"
lsmod & modinfo:
hans@hans-GA-78LMT-S2P:~$ lsmod | grep "sk98\|sky"
sky2 59043 0
hans@hans-GA-78LMT-S2P:~$ modinfo sky2
filename: /lib/modules/3.2.0-39-generic/kernel/drivers/net/ethernet/marvell/sky2.ko
version: 1.30
license: GPL
author: Stephen Hemminger <shemminger@linux-foundation.org>
description: Marvell Yukon 2 Gigabit Ethernet driver
srcversion: 973DE291F18F5911153FD7C
alias: pci:v000011ABd00004381svsdbcsci*
alias: pci:v000011ABd00004380svsdbcsci*
alias: pci:v000011ABd00004370svsdbcsci*
alias: pci:v000011ABd0000436Dsvsdbcsci*
alias: pci:v000011ABd0000436Csvsdbcsci*
alias: pci:v000011ABd0000436Bsvsdbcsci*
alias: pci:v000011ABd0000436Asvsdbcsci*
alias: pci:v000011ABd00004369svsdbcsci*
alias: pci:v000011ABd00004368svsdbcsci*
alias: pci:v000011ABd00004367svsdbcsci*
alias: pci:v000011ABd00004366svsdbcsci*
alias: pci:v000011ABd00004365svsdbcsci*
alias: pci:v000011ABd00004364svsdbcsci*
alias: pci:v000011ABd00004363svsdbcsci*
alias: pci:v000011ABd00004362svsdbcsci*
alias: pci:v000011ABd00004361svsdbcsci*
alias: pci:v000011ABd00004360svsdbcsci*
alias: pci:v000011ABd0000435Asvsdbcsci*
alias: pci:v000011ABd00004357svsdbcsci*
alias: pci:v000011ABd00004356svsdbcsci*
alias: pci:v000011ABd00004355svsdbcsci*
alias: pci:v000011ABd00004354svsdbcsci*
alias: pci:v000011ABd00004353svsdbcsci*
alias: pci:v000011ABd00004352svsdbcsci*
alias: pci:v000011ABd00004351svsdbcsci*
alias: pci:v000011ABd00004350svsdbcsci*
alias: pci:v000011ABd00004347svsdbcsci*
alias: pci:v000011ABd00004346svsdbcsci*
alias: pci:v000011ABd00004345svsdbcsci*
alias: pci:v000011ABd00004344svsdbcsci*
alias: pci:v000011ABd00004343svsdbcsci*
alias: pci:v000011ABd00004342svsdbcsci*
alias: pci:v000011ABd00004341svsdbcsci*
alias: pci:v000011ABd00004340svsdbcsci*
alias: pci:v00001186d00004B03svsdbcsci*
alias: pci:v00001186d00004B02svsdbcsci*
alias: pci:v00001186d00004001svsdbcsci*
alias: pci:v00001186d00004B00svsdbcsci*
alias: pci:v00001148d00009E01svsdbcsci*
alias: pci:v00001148d00009E00svsdbcsci*
alias: pci:v00001148d00009000svsdbcsci*
depends:
intree: Y
vermagic: 3.2.0-39-generic SMP mod_unload modversions
parm: debug:Debug level (0=none,...,16=all) (int)
parm: copybreak:Receive copy threshold (int)
parm: disable_msi:Disable Message Signaled Interrupt (MSI) (int)
parm: legacy_pme:Legacy power management (int)
hans@hans-GA-78LMT-S2P:~$ modinfo sk98lin
filename: /lib/modules/3.2.0-39-generic/kernel/drivers/net/ethernet/marvell/sk98lin.ko
version: 10.93.3.3
license: GPL
description: Marvell/SysKonnect Yukon Ethernet Network Driver
author: Mirko Lindner <support@marvell.com>
srcversion: B6855C93810A36F7A9088B6
alias: pci:v000011ABd00005005svsdbcsci*
alias: pci:v000011ABd00004382svsdbcsci*
alias: pci:v000011ABd00004320svsdbcsci*
alias: pci:v00001186d00004C00svsdbcsci*
alias: pci:v00001186d00004B01svsdbcsci*
alias: pci:v00001148d00004320svsdbcsci*
depends:
parm: Speed_A:array of charp
parm: Speed_B:array of charp
parm: AutoNeg_A:array of charp
parm: AutoNeg_B:array of charp
parm: DupCap_A:array of charp
parm: DupCap_B:array of charp
parm: FlowCtrl_A:array of charp
parm: FlowCtrl_B:array of charp
parm: Role_A:array of charp
parm: Role_B:array of charp
parm: ConType:array of charp
parm: WolType:array of charp
parm: IntsPerSec:array of int
parm: Moderation:array of charp
parm: ModerationMask:array of charp
parm: LowLatency:array of charp
parm: TxModeration:array of int
parm: MsiIrq:array of charp
parm: RSS:array of charp
Dec 04,
OK I got it this far :
Kernel driver in use: sk98lin
03:06.0 FireWire (IEEE 1394): Texas Instruments TSB43AB23 IEEE-1394a-2000 Controller (PHY/Link)
eth0 Link encap:Ethernet HWaddr 00:1c:25:51:24:43
RX packets:105 errors:0 dropped:0 overruns:0 frame:0
TX packets:2 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:7491 (7.4 KB) TX bytes:188 (188.0 B)
Interrupt:42 Memory:fdcfc000-0
RX packets:104 errors:0 dropped:0 overruns:0 frame:0
TX packets:104 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:8224 (8.2 KB) TX bytes:8224 (8.2 KB)
But Ubuntu still reports the cable unplugged. Any suggestions?
Hans
Dec 6. Anders:- Here is the lsmod output :-
hans@hans-GA-78LMT-S2P:~$ lsmod -a
Usage: lsmod
Module Size Used by
snd_hda_codec_realtek 224173 1
k8temp 13057 0
snd_hda_intel 33719 3
snd_hda_codec 127706 2 snd_hda_codec_realtek,snd_hda_intel
snd_hwdep 17764 1 snd_hda_codec
snd_pcm 97275 2 snd_hda_intel,snd_hda_codec
snd_seq_midi 13324 0
snd_rawmidi 30748 1 snd_seq_midi
snd_seq_midi_event 14899 1 snd_seq_midi
snd_seq 61929 2 snd_seq_midi,snd_seq_midi_event
snd_timer 29990 2 snd_pcm,snd_seq
snd_seq_device 14540 3 snd_seq_midi,snd_rawmidi,snd_seq
psmouse 97485 0
sp5100_tco 13791 0
snd 79041 15 snd_hda_codec_realtek,snd_hda_intel,snd_hda_codec,snd_hwdep,snd_pcm,snd_rawmidi,snd_seq,snd_timer,snd_seq_device
i2c_piix4 13301 0
serio_raw 13211 0
edac_core 53746 0
edac_mce_amd 23709 0
soundcore 15091 1 snd
snd_page_alloc 18529 2 snd_hda_intel,snd_pcm
radeon 808704 2
bnep 18281 2
rfcomm 47604 0
bluetooth 180153 10 bnep,rfcomm
parport_pc 32866 1
ppdev 17113 0
ttm 76949 1 radeon
drm_kms_helper 46978 1 radeon
drm 241971 4 radeon,ttm,drm_kms_helper
i2c_algo_bit 13423 1 radeon
mac_hid 13253 0
shpchp 37201 0
lp 17799 0
parport 46562 3 parport_pc,ppdev,lp
usbhid 47238 0
firewire_ohci 41000 0
hid 99636 1 usbhid
pata_atiixp 13204 0
firewire_core 63600 1 firewire_ohci
crc_itu_t 12707 1 firewire_core
floppy 70207 0
sk98lin 187175 1
usb_storage 49243 0
I can only see one Ethernet driver loaded. (sk98lin) Could it be the Network Manager GUI?
Hans
Dec 6 Edit 2
Have tried a number of things,
Static IP - loads it but does not connect to router Eliminated possible IP conflict on routers - still no results. I has to be Ubuntu, Here is the working Windows ipconfig.
Microsoft Windows XP [Version 5.1.2600] (C) Copyright 1985-2001 Microsoft Corp.
C:\Documents and Settings\Hans>ipconfig
Windows IP Configuration
Ethernet adapter Local Area Connection 2:
Connection-specific DNS Suffix . : royaume.com
IP Address. . . . . . . . . . . . : 192.168.0.106
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . : 192.168.0.1
C:\Documents and Settings\Hans>ipconfig/all
Host Name . . . . . . . . . . . . : SERVER_1
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Unknown
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
DNS Suffix Search List. . . . . . : royaume.com
Description . . . . . . . . . . . : Marvell Yukon 88E8056 PCI-E Gigabit
Ethernet Controller
Physical Address. . . . . . . . . : 00-1C-25-51-24-43
Dhcp Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
DHCP Server . . . . . . . . . . . : 192.168.0.1
DNS Servers . . . . . . . . . . . : 192.168.0.1
Lease Obtained. . . . . . . . . . : Friday, December 06, 2013 1:18:08 PM
Lease Expires . . . . . . . . . . : Saturday, December 07, 2013 1:18:08
PM
So if anyone has an idea? Please I'm now well beyond my knowledge of this OS.
Thanks Hans
Here is the Dec 7 output:
hans@hans-GA-78LMT-S2P:~$ sudo cat ../../etc/NetworkManager/system-connections/*
[802-3-ethernet]
duplex=full
mac-address=00:1C:25:51:24:43
[connection]
id=Wired connection 1
uuid=d10d591a-43b6-4692-84e3-6bd53c5f4f41
type=802-3-ethernet
[ipv6]
method=auto
[ipv4]
method=auto
hans@hans-GA-78LMT-S2P:~$ cat ../../etc/network/interfaces
auto eth0
iface eth0 inet static
address 192.168.0.106
netmask 255.255.255.0
network 192.168.0.1
auto lo
iface lo inet loopback
Hans
ISSUE SOLVED !!!!
Hi all who were following this. I have solved the problem. I still don't know what caused the problem but I have solved it by installing a new PCI Network Card ( StarTech.com part # ST1000BT32. I disabled the onboard Ethernet and plugged in this card. Started up LINUX and "BING" a network connection.
So Thanks all who took the time to try to help, especially Anders.
Hope this helps some others.
Happy New Year.
Hans
