i am new to ubuntu 12.04 i am facing a lot of problem while installing vlc in my laptop every time i try to install it i get an error that the packages are broken. i have tried repairing, cleaning and removing the packages and also reinstalling it but all in vain.
i tried installing all packages manually but the same problem occured
sudo apt-get install vlc vlc-nox
i tried installing vlc using soft ware center but it showed the following error
This error could be caused by required additional software packages which are missing or not installable. Furthermore there could be a conflict between software packages which are not allowed to be installed at the same time.
vlc: Depends: vlc-nox (= 2.0.8-0ubuntu0.12.04.1) but 2.0.8-0ubuntu0.12.04.1 is to be installed
Depends: libavcodec-extra-53 (>= 4:0.8-1~) but 4:0.8.9ubuntu0.12.04.1 is to be installed
Depends: libavutil-extra-51 (>= 4:0.8-1~) but 4:0.8.9ubuntu0.12.04.1 is to be installed
Depends: libc6 (>= 2.15) but 2.15-0ubuntu10.5 is to be installed
Depends: libfreetype6 (>= 2.2.1) but 2.4.8-1ubuntu2.1 is to be installed
Depends: libgcc1 (>= 1:4.1.1) but 1:4.6.3-1ubuntu5 is to be installed
Depends: libqtcore4 (>= 4:4.8.0) but 4:4.8.1-0ubuntu4.4 is to be installed
Depends: libqtgui4 (>= 4:4.7.0~beta1) but 4:4.8.1-0ubuntu4.4 is to be installed
Depends: libsdl-image1.2 (>= 1.2.10) but it is not going to be installed
Depends: libstdc++6 (>= 4.6) but 4.6.3-1ubuntu5 is to be installed
Depends: libtar0 but it is not going to be installed
Depends: libxcb-keysyms1 (>= 0.3.8) but it is not going to be installed
Depends: zlib1g (>= 1:1.2.3.3.dfsg) but 1:1.2.3.4.dfsg-3ubuntu4 is to be installed
vlc nox shows following error
vlc-nox: Depends: liba52-0.7.4 but it is not going to be installed
Depends: libavformat-extra-53 (>= 4:0.8-1~) but 4:0.8.9ubuntu0.12.04.1 is to be installed
Depends: libc6 (>= 2.15) but 2.17-93ubuntu4 is to be installed
Depends: libcddb2 but it is not going to be installed
Depends: libdvbpsi7 (>= 0.2.0) but it is not going to be installed
Depends: libebml3 but it is not going to be installed
Depends: libfontconfig1 (>= 2.8.0) but 2.10.93-0ubuntu1 is to be installed
Depends: libfreetype6 (>= 2.2.1) but 2.4.12-0ubuntu1 is to be installed
Depends: libgcc1 (>= 1:4.1.1) but 1:4.8.1-10ubuntu8 is to be installed
Depends: libgnutls26 (>= 2.12.6.1-0) but 2.12.23-1ubuntu4 is to be installed
Depends: libmatroska5 but it is not going to be installed
Depends: libmpcdec6 (>= 1:0.1~r435) but 2:0.1~r459-1ubuntu1 is to be installed
Depends: libmpeg2-4 but it is not going to be installed
Depends: libncursesw5 (>= 5.6+20070908) but 5.9+20130608-1ubuntu1 is to be installed
Depends: libpostproc-extra-52 (>= 4:0.8-1~) but 4:0.8.9ubuntu0.12.04.1 is to be installed
Depends: libresid-builder0c2a but it is not going to be installed
Depends: libsidplay2 but it is not going to be installed
Depends: libsmbclient (>= 3.0.24) but 2:3.6.18-1ubuntu3 is to be installed
Depends: libstdc++6 (>= 4.6) but 4.8.1-10ubuntu8 is to be installed
Depends: libswscale-extra-2 (>= 4:0.8-1~) but 4:0.8.9ubuntu0.12.04.1 is to be installed
Depends: libtwolame0 but it is not going to be installed
Depends: libudev0 (>= 147) but 175-0ubuntu9.4 is to be installed
Depends: libvcdinfo0 (> 0.7.23) but it is not going to be installed
Depends: libx264-120 but it is not going to be installed
Depends: libxml2 (>= 2.7.4) but 2.9.1+dfsg1-3ubuntu2 is to be installed
Depends: zlib1g (>= 1:1.2.0.2) but 1:1.2.8.dfsg-1ubuntu1 is to be installed
@avinash i tried the first command and got this
E: Some index files failed to download. They have been ignored, or old ones used instead. W: Failed to fetch http://ppa.launchpad.net/lucid-bleed/ppa/ubuntu/dists/precise/main/source/Sources 404 Not Found W: Failed to fetch gzip:/var/lib/apt/lists/partial/in.archive.ubuntu.com_ubuntu_dists_precise_universe_binary-amd64_Packages Hash Sum mismatch
