Every time I download a torrent file (.torrent), Firefox thinks I should open it with a text editor. How can I get it to open with Transmission? In Edit -> Preferences -> Applications, there's no setting for torrent files, and no apparent way to add a new filetype.
- 7,470
Method (I): Using Firefox's Preferences menu: (preferred)
A. From Firefox's global menu, select Edit -> Preferences (or press Alt + E followed by N) to open Firefox Preferences.
(Snapshot taken in Ubuntu 12.04)
B. Select the Applications menu and search for BitTorrent seed file or application/x-bittorrent or torrent. Change the Always ask or Use gedit (default) to transmission-gtk by selecting Use other... and click File System in the side bar, then browse to /usr/bin.
C. In /usr/bin search for transmission-gtk and double click to open.
D. That's it! Now the .torrent files will be opened with transmission.
Method (2): Editing the mimeTypes.rdf file:
Step 1:
Open the mimeTypes.rdf file with text editor of your choice:
gedit ~/.mozilla/firefox/ythemo16.default/mimeTypes.rdf &
(Save a backup of this file.) Search for the container:
<RDF:Seq RDF:about="urn:mimetypes:root">
</RDF:Seq>
and insert this:
<RDF:li RDF:resource="urn:mimetype:application/x-bittorrent"/>
so that, now the container looks something like this:
</RDF:Seq>
(step 1 snapshot)
Step 2:
Now, within the container:
<RDF:RDF ... ...>
</RDF:RDF>
insert these:
<RDF:Description RDF:about="urn:mimetype:handler:application/x-bittorrent"
NC:alwaysAsk="false"
NC:saveToDisk="false">
<NC:possibleApplication RDF:resource="urn:handler:local:/usr/bin/transmission-gtk"/>
<NC:externalApplication RDF:resource="urn:mimetype:externalApplication:application/x-bittorrent"/>
</RDF:Description>
<RDF:Description RDF:about="urn:mimetype:externalApplication:application/x-bittorrent"
NC:prettyName="transmission-gtk"
NC:path="/usr/bin/transmission-gtk" />
<RDF:Description RDF:about="urn:handler:local:/usr/bin/transmission-gtk"
<RDF:Description RDF:about="urn:mimetype:application/x-bittorrent"
NC:fileExtensions="torrent"
NC:description="BitTorrent seed file"
NC:value="application/x-bittorrent"
NC:editable="true">
<NC:handlerProp RDF:resource="urn:mimetype:handler:application/x-bittorrent"/>
</RDF:Description>
so that the container will look something like this:
<RDF:RDF ... ...>
</RDF:Description>
NC:editable="true">
</RDF:Description>
</RDF:RDF>
(step 2 snapshot)
Step 3:
Save and close the file. Then restart firefox.
Open the Firefox
preferences window. Go to theApplicationstab and you should seemagneton the list. Click onAlways askand if Transmission does not appear as an option then click onUse otherand navigate to/usr/binon your file system. Look fortransmissionortransmission-gtkand click that.
Source: How to make Firefox open magnet-links in Transmission
If magnet didn't show up in the applications tab, then you should do this via about:config as explained below:
- Type
about:configinto the address bar and press Enter.- Right-click -> New -> Boolean -> Name:
network.protocol-handler.external.magnet-> Value ->true- Right-click -> New -> String -> Name:
network.protocol-handler.app.magnet-> Value ->/usr/bin/transmission- Ensure
network.protocol-handler.expose-allis set totrue
- 393
- 1
- 7
- 23
Another more user-friendly way to add a new file type to the Edit -> Preferences -> Applications window is by downloading a file that has the file format you want to add, selecting any option, and selecting the "Do this automatically for files like this from now on." checkbox. Source: firefox doc.
- 41
- 1
The answer depends on whether the server sends you the correct mime type (not just the file with the right extension). You can check whether the server is sending the correct mime type by installing the Live HTTP Headers addon for Firefox. (Start the addon just before you click on the download link for the torrent file, and watch the response header, it should contain: Content-Type: application/x-bittorrent.) If it does, then Firefox will be able to open the file with the default application currently setup on your computer. In Ubuntu you can download a torrent file, then right click and select 'Properties', there you will find a way to select the default application.
If, however, the server sends .torrent as an octet-stream or some other weird mime, then Firefox will NOT do the stupid thing and open it by extension (like some broken browsers do), since that can lead to very bad results. But every so often you are willing to take a risk, you can try https://addons.mozilla.org/en-US/firefox/addon/force-content-type/, but keep in mind that this extension is considered buggy and may actually make the matters worse.
If the server is doing it wrongly, and you are not willing to take risks, you can simply have Transmission monitor your download folder and automatically add torrent files you place there. It can even remove the files after it added them. You will find that in the settings of Transmission.
P.S. Should you need a way to keep other application as the default when double clicking, but transmission only from firefox, you can follow instructions at http://forums.mozillazine.org/viewtopic.php?f=9&t=1706945
Next time you download a torrent file, and the window pops up to ask what to do, give the path for the file to open with: /usr/bin/transmission-gtk and select it. All done.
- 897
A little bit more up-to-date solution (here, specifically Ubuntu 16.04 + FireFox 51.0.1). Useful if "torrent" doesn't appear in the Applications Menu; specially if the prompt doesn't give you the "open with" option.
Two important things for torrents: Magnet Links and Torrent Files
Magnet Links: at the address bar, type about:config.
Proceed with caution, as told, and right-click > new > boolean; in the prompt type:
network.protocol-handler.expose.magnet
Set it to false (it's important).
Then, go to somewhere with magnet links and open one of them; it'll ask which program you want to use to handle the link. I haven't used windows for some time so I'll step aside, but in Ubuntu and some other distros you'll select a file like /usr/bin/transmission (if you use transmission).
Let's say you use Tixati or "pen-pineapple-appe-pen"; then, it would look, respectively, like /usr/bin/tixati or /usr/bin/pen-pineapple-appe-pen.
Set "use this always" or a similar option and probably you'll be good to go.
Torrent Files: there are some more arcane methods certainly, but a simple one that works --- if the download prompt doesn't give you an "open with" option --- is:
Download some random torrent file you'd like to use.
Go to the top-bar and File > Open file (or Ctrl+O) and open the torrent file.
Firefox, most likely will have no clue what to do with it --- well, not exactly --- and will ask you where to open it. Select the program you want (probably in the /usr/bin/ folder for most linux users), tell it to remember and you should be good to go, since from now on it'll give you the option to automatically open torrents with your desired program.
Unfortunately, there are no such preferences available in Firefox anymore. Mozilla has removed all such functionality.
