Info: This is not needed in Ubuntu 14.04 anymore. The Tablets CTH-480 and CTH-680 work out of tho box now
I bought a wacom graphic tablet and missed to look if it is supportet by ubuntu. The Tablet is a cth-680 called "Intuos Pen & Touch".
I found, this answer on askubuntu for a CTH-480. And the patch there seems to also include the CTH-680
My ubuntu version is 13.10
The tablet is found with lsusb:
Bus 001 Device 012: ID 056a:0303 Wacom Co., Ltd
What i did so far:
sudo apt-get install build-essential libx11-dev libxi-dev x11proto-input-dev xserver-xorg-dev libxrandr-dev libncurses5-dev autoconf libtool libudev-dev
 mkdir ~/wacom
 cd ~/wacom
 git clone git://git.code.sf.net/p/linuxwacom/xf86-input-wacom
 git clone git://git.code.sf.net/p/linuxwacom/input-wacom
Then I downloaded and applied the patches:
http://sourceforge.net/p/linuxwacom/mailman/message/31592023/ as attachments to this post http://sourceforge.net/p/linuxwacom/mailman/message/31599376/
0001-Input-wacom-Not-all-multi-interface-devices-support-.patch
0002-Input-wacom-add-support-for-three-new-Intuos-devices.patch
cd input-wacom
patch -p1 < ~/Downloads/0001-Input-wacom-Not-all-multi-interface-devices-support-.patch
patch -p1 < ~/Downloads/0002-Input-wacom-add-support-for-three-new-Intuos-devices.patch
Then i compiled the driver:
./autogen.sh
./make
And did a backup and copy the new diver like so:
sudo cp /lib/modules/$(uname -r)/kernel/drivers/input/tablet/wacom.ko /lib/modules/$(uname -r)/kernel/drivers/input/tablet/wacom.ko.BAK
sudo cp 3.7/wacom.ko /lib/modules/$(uname -r)/kernel/drivers/input/tablet/wacom.ko
sudo depmod -a
Step 2 (xserver driver)
I didn't need to patch the xserver driver. Because it works on ubunt 13.10 So i compiled it:
cd ../xf86-input-wacom
./autogen.sh
./configure --prefix=/usr --libdir=/usr/lib
make
...and copied it over:
sudo cp /usr/lib/xorg/modules/input/wacom_drv.so /usr/lib/xorg/modules/input/wacom_drv.so.BAK
sudo cp src/.libs/wacom_drv.so /usr/lib/xorg/modules/input/wacom_drv.so
I rebooted the system, but still the tablet is not recognized.
Did i miss something?
Evenbit GmbH
  • 4,726
Solution was to use the drivers from
Sourceforge
directly and not the git repository. Anything else is the same.
Evenbit GmbH
  • 4,726
