I don't use bluetooth on my laptop. But my Ubuntu installation doesn't remember my preference to switch-off bluetooth. After rebooting, Blutooth is again switched on.
What is the reason? What is the solution?
Mine is Ubuntu 13.10 on a Dell inspiron laptop
Thanks, KK
mantlex
  • 55
Edit /etc/bluetooth/main.conf:
sudo gedit /etc/bluetooth/main.conf
Change InitiallyPowered = true to InitiallyPowered = false
If that doesn't works, run sudoedit /etc/rc.local and add this before line with exit 0:
rfkill block bluetooth
Source(s):
How to turn off bluetooth? [duplicate]
How can I deactivate Bluetooth on system startup?
The problem is that blueman-applet has an auto-power setting that automatically enables bluetooth each time the indicator starts. So if you you want Ubuntu to remember your preference open a terminal and type this:
$ gsettings set org.blueman.plugins.powermanager auto-power-on false
This way you can just disable bluetooth and the OS will remember it and won't automatically re-enable it next time you turn on or reboot your PC.
