Duplicate sources.list entry http://archive.ubuntu.com/ubuntu/ saucy/restricted amd64 Packages (/var/lib/apt/lists/archive.ubuntu.com_ubuntu_dists_saucy_restricted_binary-amd64_Packages)
W: Duplicate sources.list entry http://archive.ubuntu.com/ubuntu/ saucy/restricted i386 Packages (/var/lib/apt/lists/archive.ubuntu.com_ubuntu_dists_saucy_restricted_binary-i386_Packages)
Asked
Active
Viewed 1,945 times
-1
You can build a default file following the procedure:
Move older file
sudo mv /etc/apt/sources.list /etc/apt/sources.list.bakThen open
software-properties-gtkto build a new one. Type the below command in a terminalsoftware-properties-gtk
In the window
Select all four catagory in Ubuntu Software tab
Select precise-security, precise-updates and precise-backports catagory in Updates tab.
Select Canonical partner and Intependent catagory from Other software tab.
That's it. Now you will have a new deafault error free sources.list file.
