Is there a easy way to convert .mkv files into .avi files with ubuntu? I have tried downloading apps but none of which seem to work. Thanks
Get WinFF:
sudo add-apt-repository ppa:paul-climbing/ppa
sudo apt-get update
sudo apt-get install winff
Optionally:
sudo apt-get install libavcodec-extra-53
In WinFF, choose a preset like "Widescreen XVID", then load the video bitrate, framerate, resolution and audio settings with those of the MKV file (you can get them by right-clicking the file and selecting Properties > Audio/Video). Do a search on Wikipedia for "Aspect Ratio" to get the right aspect ratio settings for different resolutions. Converting a 45 minute 720P MKV to AVI takes about 20 minutes on a Core i7 with 24GB RAM.
Source: https://code.google.com/archive/p/winff/wikis/UbuntuInstallation.wiki
Handbrake is the best tool for converting .mkv files to .avi files in ubuntu.Run the following commands on terminal to install handbrake in Ubuntu 12.04,
Edit the /etc/apt/sources.list file,
sudo gedit /etc/apt/sources.list
Add the following lines to the opened sources.list file,
deb http://ppa.launchpad.net/stebbins/handbrake-snapshots/ubuntu precise main
deb-src http://ppa.launchpad.net/stebbins/handbrake-snapshots/ubuntu precise main
Then update the repositories,
sudo apt-get update
Run this command to install handbrake,
sudo apt-get install handbrake-gtk
- 80,446
AS Handbrake doesn't support AVI Output anymore you can do this very rapidly via the command line with avconv like this:
avconv -i infile.mkv -codec copy outfile.avi
By using -codec copy you are changing the container only without the need to re-encode the movie. Note: Depending on the codecs in use in the original file you may need to install the Ubuntu restricted extras package first. You can do this via either software center or via the CLI from a terminal with sudo apt-get install ubuntu-restricted-extras
Source: Experience
- 36,752
Use ffmpeg https://www.ffmpeg.org/
ffmpeg -i filename.mkv -c:v copy -c:a copy output.avi
source: https://superuser.com/questions/227338/how-to-convert-an-mkv-to-avi-with-minimal-loss
