I have heard that installing or running .tar.gz files is possible. This is a source code, also and if there is a difference I should be told about it. The game is http://www.knightsgame.org.uk/files/knights_022_src.tar.gz. Success would be great. This is a good game, It would be appreciated. ;)
Followed mikewhatever's directions below but ran into:
Reading package lists... Done
Building dependency tree
Note, selecting 'libsdl1.2-dev' instead of 'libsdl-dev'
Note, selecting 'libfontconfig1-dev' instead of 'libfontconfig-dev'
build-essential is already the newest version.
     libcurl4-gnutls-dev : Depends: libcurl3-gnutls (= 7.22.0-3ubuntu4.2) but 7.22.0-3ubuntu4.3 is to be installed
                           Depends: libgnutls-dev but it is not going to be installed
                           Depends: libldap2-dev but it is not going to be installed
                           Depends: librtmp-dev but it is not going to be installed
     libfontconfig1-dev : Depends: libfontconfig1 (= 2.8.0-3ubuntu9) but 2.8.0-3ubuntu9.1 is to be installed
     libsdl1.2-dev : Depends: libx11-dev but it is not going to be installed
                     Depends: libglu1-mesa-dev but it is not going to be installed
                     Depends: libpulse-dev but it is not going to be installed
                     Depends: libxt-dev but it is not going to be installed
                     Depends: libxext-dev but it is not going to be installed
apt-get autoclean removed the held packages.
This sends me looking for repositories but the curl and libcurl repositories are without libcurl4-gnutls-dev.
I've not installed the game, and don't know if it works, but the steps to build that particular source code should be as follows:
  • Extracting
Right-click the downloaded file, select 'Extract here'.
  • Installing dependencies
Open a terminal window (ctrl-alt-t in Ubuntu), and the command below. It will install quite a few additional files.
sudo apt-get install build-essential libboost-dev libboost-filesystem-dev libboost-system-dev libboost-thread-dev libsdl-dev libcurl4-gnutls-dev libfreetype6-dev libfontconfig-dev
  • Installing
Still in a terminal window, change to the source directory with cd knights_022_src, then run make, and wait. If it finishes without errors, run sudo make install.
mikewhatever
  • 33,013
