I've just tested Rygel, but as I understand, Rygel is a server.
What I am looking for, is to choose the music on my computer (using Rhythmbox for example) and the file (or the stream ?) is send via upnp to a network player (Pioneer N-50 from my side). Then the "sound" is played by the network player (connected to a hi-fi system).
This scheme is working fine with my android phone without any configuration. I can even chose the output of my phone player, or local, or network player.
I d like to be able to do the same from my Ubuntu desktop because the screen, the mousse... it's so comfortable. Use desktop as DMC, network player as DMR.
Thanks a lot.
Nicolas
You're looking for a UPNP DMC. Unfortunately, they're a bit thin on the ground - have a play around with gupnp-av-cp (from gupnp-tools), which should get you started at least.
bjm
  • 31
OK I've found the answer here streaming audio from ubuntu to a dlna player and for french readers, the complete adaptation is here UPnP DMR Pioneer.
Thanks a lot. Nick
Nicolas
