65
I am trying to copy from the terminal with xclip and paste it into the unity desktop environment into gedit text editor. I can copy and paste with xclip in terminal:
$ cat line-size.c | xclip
xclip -o > input5.txt
cat input5.txt
#include <stdio.h>
However, when I press control + v to paste into gedit, it only pastes the actual last thing I copied within unity desktop, such as something from firefox browser.
How can I paste in gui applications something I copied from terminal?
Braiam
  • 69,112
JohnMerlino
  • 7,829
I think it is just a matter of understanding the different selection clipboards used by the xclip utility
   -selection
          specify  which X selection to use, options are "primary" to use
          XA_PRIMARY (default), "secondary" for  XA_SECONDARY  or  "clip‐
          board" for XA_CLIPBOARD
When you do cat line-size.c | xclip the default behaviour is to copy to the primary X selection buffer - to paste from that buffer, you need to use a mouse middle-click instead of the Ctrl+v combination.
To copy into the clipboard instead, so that you can paste with Ctrl+v, you would need to do
cat line-size.c | xclip -selection clipboard
steeldriver
  • 142,475
15
Just in case if someone is looking for a shortest version without using aliases. By using something|xclip -se c instead of just bare something|xclip you can press Ctrl+V/Ctrl+Shift+V and see a desirable result. Where something — cat somefile.txt for example.
daGo
  • 376
