How can I access my phpMyAdmin. I got the following error message:
Error
MySQL said: Documentation
#2002 - The server is not responding (or the local MySQL server's socket is not correctly configured)
Connection for controluser as defined in your configuration failed.
karel
  • 122,292
  • 133
  • 301
  • 332
It turns out that the solution is to stop all the services and solve the “Another daemon is already running” issue. I am assuming that you have installed it as in /opt/lampp/lampp
The commands you can try to solve the issue are as follows:
sudo /opt/lampp/lampp stop
sudo /etc/init.d/apache2 stop
sudo /etc/init.d/mysql stop
You can also type instead:
sudo service apache2 stop
sudo service mysql stop
After that, we start again the lampp services:
sudo /opt/lampp/lampp start
Now, there must be no problems while opening:
http://localhost
http://localhost/phpmyadmin
Hope it will work..Answer could be more accurate if I would be able to have that attached screen short that you have not uploaded other then just caption.
vinayawsm
  • 437
Sukupa91
  • 3,067
