I'm trying to install the package: libhdf5-serial-dev using the following terminal command:
sudo apt-get install libhdf5-serial-dev
This gives me the following output:
Reading package lists... Done
Building dependency tree
The following NEW packages will be installed
libhdf5-serial-dev
0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
Need to get 0 B/2,126 kB of archives.
After this operation, 14.2 MB of additional disk space will be used.
(Reading database ... 186283 files and directories currently installed.)
Unpacking libhdf5-serial-dev (from .../libhdf5-serial-dev_1.8.4-patch1-3ubuntu2_i386.deb) ...
dpkg: error processing /var/cache/apt/archives/libhdf5-serial-dev_1.8.4-patch1-3ubuntu2_i386.deb (--unpack):
trying to overwrite '/usr/include/hdf5.h', which is also in package hdf5 1.8.12-2
dpkg-deb: error: subprocess paste was killed by signal (Broken pipe)
A similar post on askubuntu was fixed using a command of the form:
sudo dpkg -r libhdf5-serial-dev_1.8.4-patch1-3ubuntu2_i386
but this gives me the error:
dpkg: warning: there's no installed package matching libhdf5-serial-dev_1.8.4-patch1-3ubuntu2_i386
I was hoping someone could explain the origin of the initial error and suggest a fix.
