My disk have 3 partition, one for system and others for store data. I can change its label, but I can not change path for that partition. My partition have a "work" label name, but I must input /media/dd7e8652-201e-4ea6-bb9b-8469091ecb25 to access in command line.
How can I access via /media/work command?
Thank for any command and answer :-)
Check your fstab,Just edit your fstab.. here's mine.
NOTE: *The second colum is the mount path **I use umask=000 because of folder permissions on Windows<>Linux
If you have trouble with umask here's a good article:
http://www.omaroid.com/fstab-permission-masks-explained/
# /etc/fstab: static file system information.
# Use 'blkid' to print the universally unique identifier for a
# device; this may be used with UUID= as a more robust way to name devices
# that works even if disks are added and removed. See fstab(5).
# <file system> <mount point>   <type>  <options>       <dump>  <pass>
proc            /proc           proc    nodev,noexec,nosuid 0       0
# / was on /dev/sdb1 during installation
UUID=25677686-3338-406d-bb07-bcf2584cb8d9 /               ext4    errors=remount-ro,user_xattr 0       1
# /mount/DATA was on /dev/sdc1 during installation
UUID=79239C344158404E /media/DATA     ntfs    defaults,umask=000,gid=46 0       0
# /mount/VM was on /dev/sda1 during installation
UUID=00602055602053A6 /media/VM       ntfs    defaults,umask=000,gid=46 0       0
# swap was on /dev/sdb5 during installation
UUID=dbca6161-c0ad-4646-8d49-6e5243433a76 none            swap    sw              0       0
Camoril
  • 34
