$ sudo apt-get --purge remove libpixman-1-0
Reading package lists... Done
Building dependency tree
libatk-wrapper-java : Depends: default-jre but it is not going to be installed or
java2-runtime
Recommends: libatk-wrapper-java-jni but it is not going to be installed
E: Error, pkgProblemResolver::Resolve generated breaks, this may be caused by held packages.
Asked
Active
Viewed 435 times
