I'm broadcasting to Justin TV with this script found on Github on Ubuntu 12.04.
I am having issues with the audio going out of sync and getting worse as I go through my playlist.
This is the code I'm using for avconv. And I can't figure out how to set the bitrate for the audio. I've seen -b as bandwidth but it looks like it should be the audio bitrate.
How to resolve this ?
avconv \
  -f x11grab -s $INRES  -r "$FPS" -i :0.0 \
  -f alsa -ac 2 -i pulse  \
  -vcodec libx264 -s $OUTRES -preset $QUAL \
  -acodec libmp3lame -ar 44100 -threads 4 -qscale 3 -b:a 98304  -bufsize 512k \
  -f flv "rtmp://live.justin.tv/app/$STREAM_KEY"
Kranium31
Try this:
Edit /etc/pulse/daemon.conf
make sure it contains these lines (adding or uncommenting)
default-sample-rate = 44100 alternate-sample-rate = 44100
Nade
  • 331
