I recently installed gnome3 on my Ubuntu partition (on a suspicion that unity is memory leaking) and now my mouse has disappeared from both the login screen and after logged in. I used these instructions to install it on my Ubuntu 13.10 this morning so it should be the most recent version I think. Does anyone know what causes this or how to fix it?
avorum
  • 115
Try this:
  • open a terminal an run gsettings set org.gnome.settings-daemon.plugins.cursor active false OR
  • run dconf-editor and navigate to org.gnome.settings-daemon.plugins.cursor and set the schema active to false.
Discussions can be find here
user224234
  • 46
  • Open System Settings > Displays by pressing window key and search for system settings in dash.
  • In the Displays window, you will see an Unknown monitor. Click it and disable it
Avinash Raj
  • 80,446
If you are using an old NVIDIA card try installing
apt-get install nvidia-common
Important:
Don't run nvidia-config and don't create any xorg.conf file now!
Then reboot
apt-get install nvidia-173
reboot
I don't know if there has to be several reboots, but the first time I tried it without installing nvidia-common first and this messed up with my resolution for my LCD monitor
rubo77
  • 34,024
  • 52
  • 172
  • 299
