100
I've got a .dmg file, and I can't figure out how to open it. How can I open it?
kiri
  • 28,986
jrg
  • 61,707
9 Answers9
81
To extract it, it is much easier to use 7zip:
7z x file.dmg
rumpel
  • 1,209
66
Install dmg2img.
Next, read the package information page and the manual page to see if it is useful to you.
The application seems to convert .dmg to a file that can be mounted using the mount command:
dmg2img file.dmg imagefile.img
From your Wikipedia article, the next command seems to be available to do that:
sudo mount -o loop -t hfsplus imagefile.img /mnt
In this way, the file imagefile.img is a result from dmg2iso and the contents will be available at /mnt. If the hfsplus type is not detected, you might need to load the kernel module for it:
sudo modprobe hfsplus
When done, you can unmount it by running:
sudo umount /mnt
Lekensteyn
  • 178,446
33
This works for me:
  • Extract using 7z x
  • Locate the hfs partition file
  • Mount it to a directory
Extract using 7z x
root # aptitude install p7zip-full
root # 7z x ../mysql-5.5.28-osx10.6-x86_64.dmg
7-Zip [64] 9.20  Copyright (c) 1999-2010 Igor Pavlov  2010-11-18
p7zip Version 9.20 (locale=en_IN,Utf16=on,HugeFiles=on,4 CPUs)
Processing archive: ../mysql-5.5.28-osx10.6-x86_64.dmg
Extracting  0.MBR
Extracting  1.Primary GPT Header
Extracting  2.Primary GPT Table
Extracting  3.free
Extracting  4.hfs
Extracting  5.free
Extracting  6.Backup GPT Table
Extracting  7.Backup GPT Header
Everything is Ok
Files: 8
Compressed: 117543935
root # ls
0.MBR  1.Primary GPT Header  2.Primary GPT Table  3.free  4.hfs  5.free  6.Backup GPT Table  7.Backup GPT Header
Locate the hfs partition ( here it is 4.hfs file ):
root # ls -l
total 122548
-rw-r--r-- 1 root root       512 Feb  5 16:06 0.MBR
-rw-r--r-- 1 root root       512 Feb  5 16:06 1.Primary GPT Header
-rw-r--r-- 1 root root     16384 Feb  5 16:06 2.Primary GPT Table
-rw-r--r-- 1 root root      3072 Feb  5 16:06 3.free
-rw-r--r-- 1 root root 125435904 Feb  5 16:06 4.hfs
-rw-r--r-- 1 root root      2560 Feb  5 16:06 5.free
-rw-r--r-- 1 root root     16384 Feb  5 16:06 6.Backup GPT Table
-rw-r--r-- 1 root root       512 Feb  5 16:06 7.Backup GPT Header
Mount it to folder:
root # mkdir t
root # mount -oloop 4.hfs t
root # cd t/
root # ls
mysql-5.5.28-osx10.6-x86_64.pkg  MySQL.prefPane  MySQLStartupItem.pkg  ReadMe.txt
tuxdna
  • 441
If you succeed with the instructions from Lekensteyn and binfalse more power to you. If you are getting
$ lsmod | grep hfs
hfs                    54782  0
hfsplus                84912  0
$ sudo mount -o loop,ro -t hfsplus imagefile.img /mnt
mount: wrong fs type, bad option, bad superblock on /dev/loop0,
Right now Ubuntu only comes with dmg2img version 1.6.2 and version 1.6.4 sometimes makes a difference. Also you can extract specific partitions from a dmg and only some of them are hfs+
$ dmg2img -l file.dmg
partition 0: Protective Master Boot Record (MBR : 0)
partition 1: GPT Header (Primary GPT Header : 1)
partition 2: GPT Partition Data (Primary GPT Table : 2)
partition 3:  (Apple_Free : 3)
partition 4: disk image (Apple_HFS : 4)
partition 5:  (Apple_Free : 5)
partition 6: GPT Partition Data (Backup GPT Table : 6)
partition 7: GPT Header (Backup GPT Header : 7)
$ dmg2img -p 4 file.dmg imagefile.img
  • Current Ubuntu versions come with 1.6.5 as of version 14.04
Jorge Castro
  • 73,717
In the case of some .dmgs, you can neither 7z x them, nor mount the result of dmg2img.
In that case, the .img resulting from dmg2img your.dmg new.img can have its paritions extracted with 7z x:
$ 7z x factor-macosx-x86-64-0.98.dmg
Extracting archive: factor-macosx-x86-64-0.98.dmg
ERROR: factor-macosx-x86-64-0.98.dmg
Open ERROR: Can not open the file as [Dmg] archive
$ dmg2img factor-macosx-x86-64-0.98.dmg factor.img
factor-macosx-x86-64-0.98.dmg --> factor.img
Archive successfully decompressed as factor.img
$ sudo mount -o loop -t hfsplus factor.img /mnt
mount: /mnt: wrong fs type, bad option, bad superblock on /dev/loop5, missing codepage or helper program, or other error.
$ 7z x factor.img
Extracting archive: factor.img
Everything is Ok
Folders: 2717
Files: 10266
Compressed: 264214528
$ ls -lah factor factor/factor/
factor:
total 24K
drwx------  6 cat cat 4.0K Jul 30  2018  .
drwxr-xr-x 21 cat cat 4.0K Feb 19 16:28  ..
drwx------  8 cat cat 4.0K Jul 30  2018  factor
drwx------  2 cat cat 4.0K Jul 30  2018 '[HFS+ Private Data]'
drwx------  2 cat cat 4.0K Jul 30  2018 '.HFS+ Private Directory Data'$'\r'
drwx------  2 cat cat 4.0K Jul 30  2018  .Trashes
factor/factor/:
total 97M
drwx------   8 cat cat 4.0K Jul 30  2018 .
drwx------   6 cat cat 4.0K Jul 30  2018 ..
drwx------ 163 cat cat 4.0K Jul 30  2018 basis
drwx------  45 cat cat 4.0K Jul 30  2018 core
-rw-r--r--   1 cat cat  702 Jul 30  2018 .dir-locals.el
drwx------ 288 cat cat  12K Jul 30  2018 extra
-rw-r--r--   1 cat cat   32 Jul 30  2018 factor
drwx------   3 cat cat 4.0K Jul 30  2018 Factor.app
-rw-r--r--   1 cat cat  97M Jul 30  2018 factor.image
-rw-r--r--   1 cat cat   40 Jul 30  2018 .gitattributes
-rw-r--r--   1 cat cat   43 Jul 30  2018 git-id
-rw-r--r--   1 cat cat 366K Jul 30  2018 libfactor.dylib
-rw-r--r--   1 cat cat  16K Jul 30  2018 libfactor-ffi-test.dylib
-rw-r--r--   1 cat cat 1.3K Jul 30  2018 LICENSE.txt
drwx------   9 cat cat 4.0K Jul 30  2018 misc
-rw-r--r--   1 cat cat 4.6K Jul 30  2018 README.md
-rw-r--r--   1 cat cat 3.6K Jul 30  2018 .travis.yml
drwx------   2 cat cat 4.0K Jul 30  2018 work
Success!
cat
  • 1,712
When using dmg2img file.dmg imagefile.img on linux if you get ERROR: Inflation failed message, just install 7zip as
sudo aptitude install p7zip-full
and issue the following command on terminal
7z x your_file.dmg
  • find the InstallMacOSX.pkg/InstallESD.dmg
  • issue the command dmg2img InstallESD.dmg imagefile.img on the terminal.
Now you can mount imagefile.img with
modprobe hfsplus
and then
mount -t hfsplus -o loop mountain.img /mnt
Olorin
  • 3,548
aman
  • 151
First of all install DMG2IMG. Now you can convert it to IMG:
The IMG can be mounted with:
sudo mount -t hfsplus -o loop new.img /mnt
And take a look at /mnt
binfalse
  • 889
following the answer of @aman and @tuxdna, because dmg2img doesn't seem to work on compressed dmg images.
so i made a bash script (tested on ubuntu 14.10) to automatize the process of :
  • extracting with 7z in a temp folder
  • looking for which partition to mount
  • copy the hfs/hfsplus folder/partition somewhere else
  • delete the temp folder
  • mount the partition
find it here: https://github.com/aurelien-rainone/scripts/blob/master/mountdmg.sh
example of use:
panty@Computerino:[~/scripts]: mountdmg.sh -t hfsplus -d /mnt ~/Downloads/cutecom-ng.dmg
p7zip Version 9.20 (locale=en_US.UTF-8,Utf16=on,HugeFiles=on,2 CPUs)
Processing archive: /home/panty/Downloads/cutecom-ng.dmg
Extracting  0.MBR
Extracting  3.free
Extracting  4.hfs
Extracting  5.free
Everything is Ok
Files: 8
Compressed: 10059312
mountdmg.sh: successfully mounted 4.hfs on /dev/loop0
mountdmg.sh: run sudo umount /dev/loop0 when finished
arainone
  • 113
The instructions in some of the posts to this topic only work on older versions of 7z.
If you want to extract JUST the 4.hfs file from a .dmg file (i.e: just one level deep) and are using a newer version of 7-zip then you need to use different parameters:
In 7-Zip [64] 9.20 you can use this command:
7z x file.dmg 4.hfs
In 7-Zip [64] 16.02 you need to use this command:
7z x -t* file.dmg 4.hfs
