Whenever I try executing Sublime Text 2 from my terminal by typing sublime-text, it give the following:
/usr/bin/sublime-text: line 3: /opt/sublime_text_2/sublime_text: No such file or directory
Moreover, there are two icons in the menu, none of which work.
These are the following things I tried:
  1. Autoremove
  2. Reinstallation
  3. apt-get upgrade
But none of these seem to work. What should I do?
Ranveer
  • 285
Running the following should work to reinstall Sublime Text 2, and install Sublime Text 3:
sudo rm -rf /opt/sublime_text_2 /usr/bin/sublime-text
# this will remove the old install directory and execution script
sudo add-apt-repository ppa:webupd8team/sublime-text-2
# add the ST2 repository
sudo add-apt-repository ppa:webupd8team/sublime-text-3
# same for ST3
sudo apt-get update
sudo apt-get install sublime-text sublime-text-installer
# install ST2 and ST3, respectively
You should now be able to run sublime-text from the command line to start ST2, and subl to start ST3. As always, please keep in mind the following:
Sublime Text may be downloaded and evaluated for free, however a license must be purchased for continued use.
MattDMo
  • 2,115
