I am trying to combine some PNG images to make a GIF animation. To do this I have installed ImageMagic and am trying to execute the command:
I have a lot of image files that I am trying to combine so I don't really want to type them all out individually, is there anyway I can execute this command as some sort of loop, or alternatively a better method of creating an animation from these images?
I have written a program to output all the file names so I can just copy and paste them into the terminal, this works but if anyone knows a better way to do this it would be helpful.
Thanks
If I understand correctly, if you have mypgrogram that outputs the list of filenames, you should be able to simply do
The $(...) operator is a bash shell operation that runs the indicated command and then replaces itself with the output (more or less... the shell is a quite powerful tool).
Rmano
  • 32,167
