I've recently installed Ubuntu 13.04 on the Beagle Bone Black. This image:
https://rcn-ee.net/deb/flasher/raring/BBB-eMMC-flasher-ubuntu-13.04-2013-10-08.img.xz
This microcontroller allows to share internet connection between host PC (Version 12.04 (precise) (64-Bit), Kernel Linux 3.2.0-56-generic) and BeagleBone over USB, so I went for it and configured the device as follows:
BeagleBone Black:
ifconfig usb0 192.168.7.2
route add default gw 192.168.7.1
Host PC:
sudo su
#eth0 is my internet facing interface, eth3 is the BeagleBone USB connection
ifconfig eth2 192.168.7.1
iptables --table nat --append POSTROUTING --out-interface eth0 -j MASQUERADE
iptables --append FORWARD --in-interface eth2 -j ACCEPT
echo 1 > /proc/sys/net/ipv4/ip_forward
After that Internet Connection works itself, when I do ping 8.8.8.8 I get the results:
PING 8.8.8.8 (8.8.8.8) 56(84) bytes of data.
64 bytes from 8.8.8.8: icmp_req=1 ttl=47 time=4.63 ms
64 bytes from 8.8.8.8: icmp_req=2 ttl=47 time=4.68 ms
64 bytes from 8.8.8.8: icmp_req=3 ttl=47 time=4.57 ms
64 bytes from 8.8.8.8: icmp_req=4 ttl=47 time=4.58 ms
^C
--- 8.8.8.8 ping statistics ---
4 packets transmitted, 4 received, 0% packet loss, time 3005ms
rtt min/avg/max/mdev = 4.578/4.620/4.682/0.063 ms
To have DNS configured too I typed aswell echo "nameserver 8.8.8.8" >> /etc/resolv.conf but unfortunately when I do ping google.com I get, after few seconds of computing, ping: unknown host google.com
So - I know, that this solution isn't good, but for this session it could work and it doesn't. What's more, both - BBB and PC - use resolvconf. To be honest I've got no clue how to configure network using this program... I tried changing /etc/network/interfaces on Beagle Bone Black like this:
# This file describes the network interfaces available on your system
# and how to activate them. For more information, see interfaces(5).
# The loopback network interface
auto lo
iface lo inet loopback
# The primary network interface
#auto eth0
iface eth0 inet dhcp
# Example to keep MAC address between reboots
#hwaddress ether DE:AD:BE:EF:CA:FE
# WiFi Example
#auto wlan0
#iface wlan0 inet dhcp
# wpa-ssid "essid"
# wpa-psk "password"
# Ethernet/RNDIS gadget (g_ether)
# ... or on host side, usbnet and random hwaddr
# Note on some boards, usb0 is automaticly setup with an init script
# in that case, to completely disable remove file [run_boot-scripts] from the boot partition
auto usb0
iface usb0 inet static
address 192.168.7.2
netmask 255.255.252.0
network 192.168.7.0
#broadcast 192.168.7.3
gateway 192.168.7.1
dns-nameservers 8.8.8.8 8.8.4.4
but it didn't help.
I don't know what else should I do. Please help.
Additional useful infos:
Beagle Bone Black: ifconfig
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
usb0 Link encap:Ethernet HWaddr ce:39:f3:4a:c7:94
inet addr:192.168.7.2 Bcast:192.168.7.3 Mask:255.255.255.252
inet6 addr: fe80::cc39:f3ff:fe4a:c794/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:608 errors:0 dropped:0 overruns:0 frame:0
TX packets:375 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:57484 (57.4 KB) TX bytes:63078 (63.0 KB)
route
Kernel IP routing table
Destination Gateway Genmask Flags Metric Ref Use Iface
default 192.168.7.1 0.0.0.0 UG 0 0 0 usb0
192.168.7.0 * 255.255.255.252 U 0 0 0 usb0
uname -a
Linux arm 3.8.13-bone28 #1 SMP Fri Sep 13 03:12:24 UTC 2013 armv7l armv7l armv7l GNU/Linux
/etc/resolv.conf
nameserver 8.8.8.8
nameserver 8.8.4.4
#domain localdomain
#search localdomain
#nameserver 192.168.1.1
PC:
ifconfig
eth0 Link encap:Ethernet Hardware Adresse 00:17:31:8d:6a:a6
inet Adresse:141.3.81.154 Bcast:141.3.83.255 Maske:255.255.252.0
inet6-Adresse: fe80::217:31ff:fe8d:6aa6/64 Gültigkeitsbereich:Verbindung
UP BROADCAST RUNNING MULTICAST MTU:1500 Metrik:1
RX packets:30732 errors:0 dropped:0 overruns:0 frame:0
TX packets:5888 errors:0 dropped:0 overruns:0 carrier:0
Kollisionen:0 Sendewarteschlangenlänge:1000
RX-Bytes:7266589 (7.2 MB) TX-Bytes:1286462 (1.2 MB)
Interrupt:19
eth1 Link encap:Ethernet Hardware Adresse 00:04:75:ca:98:ee
UP BROADCAST MULTICAST MTU:1500 Metrik:1
RX-Bytes:0 (0.0 B) TX-Bytes:0 (0.0 B)
Interrupt:21 Basisadresse:0xe400
eth2 Link encap:Ethernet Hardware Adresse c8:a0:30:ac:2c:95
inet Adresse:192.168.7.1 Bcast:192.168.7.3 Maske:255.255.255.252
inet6-Adresse: fe80::caa0:30ff:feac:2c95/64 Gültigkeitsbereich:Verbindung
RX packets:418 errors:0 dropped:0 overruns:0 frame:0
TX packets:637 errors:0 dropped:0 overruns:0 carrier:0
RX-Bytes:45704 (45.7 KB) TX-Bytes:88161 (88.1 KB)
lo Link encap:Lokale Schleife
inet Adresse:127.0.0.1 Maske:255.0.0.0
inet6-Adresse: ::1/128 Gültigkeitsbereich:Maschine
UP LOOPBACK RUNNING MTU:16436 Metrik:1
RX packets:840 errors:0 dropped:0 overruns:0 frame:0
TX packets:840 errors:0 dropped:0 overruns:0 carrier:0
Kollisionen:0 Sendewarteschlangenlänge:0
RX-Bytes:142988 (142.9 KB) TX-Bytes:142988 (142.9 KB)
route
Ziel Router Genmask Flags Metric Ref Use Iface
default i60-gw-int.ipr. 0.0.0.0 UG 0 0 0 eth0
141.3.80.0 * 255.255.252.0 U 1 0 0 eth0
link-local * 255.255.0.0 U 1000 0 0 eth2
192.168.7.0 * 255.255.255.252 U 1 0 0 eth2
uname -a
Linux i60p354 3.2.0-56-generic #86-Ubuntu SMP Wed Oct 23 09:20:45 UTC 2013 x86_64 x86_64 x86_64 GNU/Linux
What can be important - PC, which share Internet with BBB works in the University network, which is far more complicated than normal home network - could that cause problems with DNS resolving? Whats important yet - if I set a nameserver that makes sense in resolv.conf.d/head (which is simply up and running like 8.8.8.8) and type ping google.com the maschine computes for some time and than returns error unknown host. If I set a nonsense adress, which surely doesn't work (ie 123.123.123.123) error is being returned immediately.
