I did everything according to these instructions on the OwnCloud forum but I get the error:
Data directory (/mnt/usbdrive/owncloud/) is readable for other users
Please change the permissions to 0770 so that the directory cannot be listed by other users.
I gave the permissions like:
 chmod 0770 /mnt/usbdrive/owncloud/
and I changed my /etc/fstab
I used:
chown -R www-data:www-data /mnt/usbdrive/owncloud/
as well. But I still get that error when going to owncloud
This is what my /etc/fstab looks like:
[screenshot of fstab in terminal
EDIT: This error only comes up when I change the data directory. If I keep it the same, I can acces it normally.
Zanna
  • 72,312
Loko
  • 131
With the inputs you provided, you have to change your mount options in /etc/fstab.
quiet,defaults,permissions,locale=en_US.utf8
Don't use the umask option; it seems that the mount.ntfs-3g manpage is false where it claims that mask will apply to newer files. All the ".mask" options apply also to already existing files.
With umask=0 all your files get rwxrwxrwx rights.
darxtrix
  • 123
Emmanuel
  • 1,333
I assume you're new to using Linux commands. In Linux, there is a SuperUser named Root which by default is locked (you can unlock it though). But you can still run programs with root-level privileges. This is where sudo comes in - it allows authorized users to run certain programs as Root. And you'll find yourself using sudo very often while performing the administrative tasks.
Changing file mode bits and ownership in /mnt directory will require root privileges. So if you haven't already done this, run the commands with sudo as:
sudo chmod 0770 /mnt/usbdrive/owncloud/
sudo chown www-data:www-data /mnt/usbdrive/owncloud/
rusty
  • 16,917
  1. First find the uid (user id) and gid (group id) for your mount (do a grep in /etc/passwd and /etc/group).
  2. Then add an entry in /etc/fstab
/etc/fstab
/dev/sda1 /mnt/usbdrive ntfs-3g  quiet,locale=en_US.utf8,uid=1001,gid=33,dmode=770,fmode=660,comment=systemd.automount 0 0
EDIT: quite to quiet
