42
I just got myself a dedicated server that's running Ubuntu 13.10 64BIT and it is in French language (console.online.net). Is there any way to install an English language package ?
I'm a Linux newbie and the fact that its in French doesn't help
Sorry, the comments didn't work for me so I just edit here :
I get:
Lecture des listes de paquets... Fait
Construction de l'arbre des dépendances
Lecture des informations d'état... Fait
E: Impossible de trouver le paquet language-support-en
When I type sudo apt-get install language-support-en
Somehow it doesn't just work :(
weeGstrom
  • 421
7 Answers7
41
First install all the English language packages:
sudo apt-get install language-pack-en language-pack-en-base manpages
Then remove the French language packages:
sudo apt-get remove language-pack-fr language-pack-fr-base manpages-fr
And that should be enough.
Edit I: some users note that you might need to update the /etc/default/locale file yourself, make sure the first line in that file reads something like:
LANG="en_GB.UTF-8"
Edit II: some users do not seem happy with the suggestion for the English used in Europe (I am assuming the enquirer is French). Those wishing to use a different English locale can get a list of available English locales with this command:
locale -a | grep en_
21
Just install language-pack or edit the /etc/default/locale doesn't work for my Ubuntu 17.10, the way below is working for me.
Regenerating the supported locale list: sudo dpkg-reconfigure locales, and choose en_US.UTF-8.
Change the current default locale: sudo update-locale LANG=en_US.UTF-8
Then it works, doesn't need reboot.
Run locale to check your current locale.
Key Shang
  • 411
12
You need to edit /etc/default/locale so it contains
LANG=en_US.UTF-8
or some other English locale of your choice.
To install English language pack
If you get the same error again , first run sudo apt-get update
Raja G
  • 105,327
  • 107
  • 262
  • 331
Simply run:
It will start the setup for system-language
Had the same problem ... with online.net :) This is what I'v made...
Edited /etc/default/locale and ~/.pam_environment
nano /etc/default/locale
Replaced the french line/lines with
LANG="en_US"
LANGUAGE="en_US:en"
Now pam_environment
nano ~/.pam_environment
LANG=en_US
LANGUAGE=en_US
PJunior
  • 355
This Packages should be installed:
Then edit /etc/default/locale and set
sudo vim /etc/default/locale
LANG=en_US.UTF-8
SScholl
  • 121
