I have had windows eight and Ubuntu 13.04 dual booting and working fine(using EasyBCD) I had created partition for Ubuntu of exactly 20GB. Some time later, after never using Ubuntu, I went into Window's partition tool and deleted my Ubuntu partition. It said it erased everything on it. I then added this 20GB onto my hardrive/windows8 partition. I also deleted easy BCD. Everything was going fine. I turned the computer off that night and this morning it said
 'windows failed to start. A recent hardware or software change might be the cause'
   File:\NSTAutoNeoGrub1.mbr
   status: 0xc000000fI
I re-installed Ubuntu from a USB and all my data and Windows system files are there, but I am stuck running ubuntu. I believe all I need to do is find the 'windows8.exe' file and boot from that. Can someone please help here?
My error report for boot-repair is: http://paste.ubuntu.com/6426199/ Also I tried updating grub using:
- sudo update-grub, but:Generating grub.cfg ... Found linux image:
   /boot/vmlinuz-3.11.0-13-generic Found initrd image:
   /boot/initrd.img-3.11.0-13-generic Found linux image:
   /boot/vmlinuz-3.11.0-12-generic Found initrd image:
   /boot/initrd.img-3.11.0-12-generic Found memtest86+ image:
   /boot/memtest86+.bin Found Windows 8 (loader) on /dev/sda1 Found
   Windows 7 (loader) on /dev/sda2 Adding Aptosid
   2010-02-keres-kde-lite-amd64-201009132215 on /dev/sda5 proc sysfs
   none none none none udev devpts tmpfs none none none none systemd
   gvfsd-fuse gvfsd-fuse /dev/sda2 Aptosid
   gvfsd-fuse gvfsd-fuse /dev/sda2 error: syntax error. error: Incorrect
   command. error: syntax error. Syntax error at line 296 Syntax errors
   are detected in generated GRUB config file. Ensure that there are no
   errors in /etc/default/grub and /etc/grub.d/* files or please file a
   bug report with /boot/grub/grub.cfg.new file attached.done
My grub file is:
 If you change this file, run 'update-grub' afterwards to update
 For full documentation of the options in this file, see:
   info -f grub -n 'Simple configuration'
GRUB_DEFAULT=0
GRUB_HIDDEN_TIMEOUT=0
GRUB_HIDDEN_TIMEOUT_QUIET=true
GRUB_TIMEOUT=10
GRUB_DISTRIBUTOR=`lsb_release -i -s 2> /dev/null || echo Debian`
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash"
GRUB_CMDLINE_LINUX=""
 Uncomment to enable BadRAM filtering, modify to suit your needs
 This works with Linux (no patch required) and with any kernel that obtains
 the memory map information from GRUB (GNU Mach, kernel of FreeBSD ...)
GRUB_BADRAM="0x01234567,0xfefefefe,0x89abcdef,0xefefefef"
 Uncomment to disable graphical terminal (grub-pc only)
GRUB_TERMINAL=console
 The resolution used on graphical terminal
 note that you can use only modes which your graphic card supports via VBE
 you can see them in real GRUB with the command `vbeinfo'
 Uncomment if you don't want GRUB to pass "root=UUID=xxx" parameter to Linux
GRUB_DISABLE_LINUX_UUID=true
 Uncomment to disable generation of recovery mode menu entries
GRUB_DISABLE_RECOVERY="true"
 Uncomment to get a beep at grub start
GRUB_INIT_TUNE="480 440 1"
   GRUB_GFXMODE=1366x768
Boot windows installation disc,and click on the option Repair your computer on startup.And then select command prompt option.Run the below commands on that,
bootrec /fixmbr
bootrec /fixboot
bootrec /rebuildbcd
Avinash Raj
  • 80,446
