This answer has been fully tested on a real system, three times: on Ubuntu 18.04, 20.04, and 22.04.
How to fully delete (or reset) your home dir at ~ (or /home/my_username), even while actively logged into that user
There's no teacher better than experience.
WARNING WARNING WARNING: do not run any of the rm commands below unless you want to wipe your whole user home directory or system! This is to do a full user wipe and reset, if that is what you want. Also, UNPLUG ANY EXTERNAL DRIVES, AND UNMOUNT ANY MOUNTED DISKS IN YOUR HOME DIR, BEFORE RUNNING THE rm COMMAND OR ELSE THIR CONTENTS WILL BE DELETED TOO!
Nope! Doing the command you said will not work as desired. I literally just tried this for a user I wanted to reset. That's right. I actually ran it. rm -rf /home/my_username/* does not work, because the shell glob pattern * does not match hidden files and folders! That means it leaves in a ton of your data, including your trash can, which is at ~/.local/share/Trash. Hidden files and folders begin with a dot (.), and using the glob pattern /home/my_username/* leaves in all hidden files and folders immediately in your home dir.
Therefore, do this instead:
The quick answer:
# First, CLOSE ALL OPEN PROGRAMS, such as Chrome, editors, etc.
# Leave open only one terminal to run the following commands in.
WARNING WARNING WARNING WARNING WARNING WARNING WARNING
- Do NOT accidentally run this on the wrong computer while testing!
- see the big warning above.
- UNPLUG ANY DRIVES FIRST!
- And UNMOUNT ANY MOUNTED DISKS IN YOUR HOME DIR FIRST!
Delete your entire home folder (see warning at start of this answer).
sudo rm -rf /home/my_username # WARNING WARNING WARNING
Now, do some "cleanup" and recreate the home dir to "reset" it for the user:
# Now, the following assumes you want to recreate an empty home dir now, and you
# are already logged in under the username whose folder you just deleted
# above.
sudo mkdir /home/my_username
ensure your group name exists (wiping your home dir may have removed it I
think, as that seems to be what happened to me just now)
sudo groupadd my_username
add your username back to this group
sudo usermod -a -G my_username my_username
give your username ownership over the new, empty home dir
sudo chown -R my_username:my_username /home/my_username
ensure everything looks right (you should see the user and group ownership
of your new home dir is 'my_username my_username')
ls -alF /home
(Optional, but recommended) restore Ubuntu's default ~/.bashrc and
~/.profile type bash terminal configuration files
cp /etc/skel/.bash_logout ~
cp /etc/skel/.bashrc ~
cp /etc/skel/.profile ~
Now re-source these files to refresh your terminal
. ~/.profile
now open your file manager, such as nemo
(see: https://askubuntu.com/a/1173861/327339)
and check inside your home dir; you'll see Ubuntu automatically has already
recreated a ~/Desktop dir for you.
ls -alF ~
Now you're done. If you left programs like Chrome open while you did this, Chrome would have kept running and may have already restored some of your user's files, so...close Chrome and start over if that's not what you want. From here on out, just opening programs will start recreating some of the deleted files and dirs for you again. Ex: open Chrome and you'll see no user is logged in anymore, but just opening the program recreates these dirs:
/home/my_username/.cache
/home/my_username/.config
/home/my_username/.local
Now log out, or restart your computer, and log back in and you'll see it's almost as though you had just created a new user. Your "start menu" (launcher) will still have all of the programs you previously installed system-wide, but user-only programs and settings and files will all be wiped. You'll even notice the following:
- your username still exists, you can still log in, and it still has the same password; but:
- your mouse speed settings have been reset
- your external monitor position and settings have been reset
- your custom Ubuntu shortcut keys are gone
- Chrome and other apps no longer have any stored users or settings
