I'm currently trying to create a writeable folder on a ext2 drive.
I took a usb drive and formatted it to ext3 using gparted.
Then I went into terminal and wrote in
sudo mkfs.ext2 -j -I 128 /dev/...
To make it an ext2 unjournaled drive.
Now I would like to make a writeable folder on that drive.
I know I should write in the command line sudo mkdir [link to drive]
My question is, where is the drive link? the code that directs terminal to the drive? Where can i find that?
I'm working on delivering a film to a cinema in a special format.
Thank you all in advance!
Richard
  • 8,588
When you plug in the USB drive, the filesystem should be mounted (made useable) in a folder under /media/[whatever your username is]. In 12.04 (and earlier), it's just a folder in /media.
If it is not mounted there automatically, mount it with sudo mount /dev/sdXY /path/to/mountpoint where /dev/sdXY is the partition name and /path/to/mountpoint is a convenient empty folder. To make an empty folder in /media, create a new one with sudo mkdir /media/mountpoint && sudo chown -R $USER /media/mountpoint.
Richard
  • 8,588
