When I report a bug I may be asked to "try out the latest upstream Kernel", how do I do that?
I see a lot of version specific answers to this question here on ask ubuntu, what are the general instructions?
Bryce
  • 2,007
Here are generic instructions that work on any version of Ubuntu:
There's a lag between when a Kernel is released, and when it's available packaged in Ubuntu updates. To add a new Kernel to the list of boot options, get the packages from here:
http://kernel.ubuntu.com/~kernel-ppa/mainline/
You'll need to match your Ubuntu version, and your 32 or 64 bit system type. Download those files to your /tmp partition using wget or something similar, and run:
sudo dpkg -i linux-*.deb
Optionally, to remove an old Kernel, find the right version number then run:
sudo apt-get purge linux-image-YYYYYY*
Once a Kernel is installed it will be available to select at boot time. Be sure to leave at least one Kernel at all times, preferably leave two (the one your system was originally supplied with, and your current version).
Bryce
  • 2,007
