After waking the system from suspend my networking is disabled and will not start again, this started happening after upgrading from 13.04 to 13.10
sudo lshw -C network
  *-network
       description: Ethernet interface
       product: RTL8101E/RTL8102E PCI Express Fast Ethernet controller
       vendor: Realtek Semiconductor Co., Ltd.
       physical id: 0
       bus info: pci@0000:02:00.0
       logical name: eth0
       version: 02
       serial: 90:fb:a6:a8:52:40
       capacity: 100Mbit/s
       width: 64 bits
       clock: 33MHz
       capabilities: pm msi pciexpress msix vpd bus_master cap_list rom ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd autonegotiation
       configuration: autonegotiation=on broadcast=yes driver=r8169 driverversion=2.3LK-NAPI duplex=half latency=0 link=no multicast=yes port=MII speed=10Mbit/s
       resources: irq:44 ioport:6000(size=256) memory:f0010000-f0010fff memory:f0000000-f000ffff memory:f0020000-f003ffff
  *-network
       description: Wireless interface
       product: BCM4313 802.11bgn Wireless Network Adapter
       vendor: Broadcom Corporation
       physical id: 0
       bus info: pci@0000:03:00.0
       logical name: eth1
       version: 01
       serial: 00:26:82:a3:fa:70
       width: 64 bits
       clock: 33MHz
       capabilities: pm msi pciexpress bus_master cap_list ethernet physical wireless
       configuration: broadcast=yes driver=wl0 driverversion=6.30.223.141 (r415941) ip=192.168.0.103 latency=0 multicast=yes wireless=IEEE 802.11abg
       resources: irq:19 memory:f1100000-f1103fff
This technique sometimes, but not always works. Please open a terminal and do:
gksudo gedit /etc/pm/config.d/config
A new, empty file will open. Add a single line:
SUSPEND_MODULES="wl"
Proofread carefully, save and close gedit. It may take a reboot to test it.
chili555
  • 61,330
Well, I had installed ubuntu 13.10 on a new machine but messed my network setting up.
  1. I installed gksu
  2. Runned: sudo gksu gedit in gedit open your network interfaces file found in etc-network-interfaces
  3. Edit the file with:
    -# This file describes the network interfaces available on your system
    -# and how to activate them. For more information, see interfaces(5).
    -# The loopback network interface
    -auto lo
    -iface lo inet loopback
    -# This is a list of hotpluggable network interfaces.
    -# They will be activated automatically by the hotplug subsystem.
    -# auto eth1
    -# iface eth1 inet dhcp
    then just save it.
  4. Just to make sure everything is ok a. please check your dhcpd.conf file found in etc-dhcp-dhcpd.conf to make sure
    option domain-name "example.org";
    option domain-name-server ns1.example.org, ns2.example.org;
    default-lease-time 600; max-lease-time 7200;
    do not have # before them.
  5. now retart your system and I hope it works just like mine did
