I tried to install shutter with the following command, but I am receiving an error:
$ sudo apt-get install shutter
Shutter:
Depends: gnome-web-photo but it is not installable
Depends: libgnome2-perl but it is not installable
Depends: libgnome2-vfs-perl but it is not installable
Depends: libgnome2-wnck-perl but it is not installable
Depends: libgoo-canvas-perl but it is not installable
Depends: libgtk2-imageview-perl but it is not installable
Depends: libgtk2-trayicon-perl but it is not installable
Depends: libgtk2-unique-perl but it is not installable
Depends: libnet-dbus-perl but it is not installable
Depends: libproc-processtable-perl but it is not installable
Depends: libwww-mechanize-perl but it is not installable
Depends: libx11-protocol-perl but it is not installable
Depends: libxml-simple-perl but it is not installable
Depends: perlmagick but it is not installable
Depends: libpath-class-perl but it is not installable
Depends: libjson-perl but it is not installable
Depends: libjson-xs-perl but it is not installable
Depends: libnet-dropbox-api-perl but it is not installable
Depends: libfile-which-perl but it is not installable
Depends: libproc-simple-perl but it is not installable
Depends: libsort-naturally-perl but it is not installable
How can I fix this?
galoget
  • 3,023
I had this problem with Shutter some time ago, the reason is that you got broken dependencies. Run this in Terminal:
sudo apt-get autoremove
sudo apt-get install -f
You can also use some Tweaks from time to time to clean your apt cache, configs, etc. For example Ubuntu Tweak, that what I used when this happend. After this I advice you to use Synaptic or Ubuntu Software Center to install Shutter.
