Ubuntu 12.04 LTS - iptables v1.4.12
TLDR:
Where are iptables's rulesets saved when invoking iptables-save <ruleset-name> ?
Explanation:
According to this answer basic way of saving iptables's rules is invoking
iptables-save > /etc/iptables/rules.v4
ip6tables-save > /etc/iptables/rules.v6
and afterwards loading/restoring these rules in /etc/network/interfaces like:
iface eth0 inet static
        pre-up iptables-restore < /etc/iptables/rules.v4
        pre-up ip6tables-restore < /etc/iptables/rules.v6
... or putting these into a shell script in /etc/network/if-pre-up.d.
This can be simplified by installing the iptables-persistent package.
sudo apt-get install iptables-persistent
inovoke-rc.d iptables-persistent save
update-rc.d iptables-persistent defaults
Following some tutorials i tried to invoke service iptables status ( a non-existant/unknown command for the iptables version/package that comes pre-installed with 12.04 ) and found this interesting output:
Aborting iptables initd: unknown command(s): "status".
  save <ruleset>
     save the current ruleset
  load <ruleset>
     load a ruleset
Saved rulesets:
  active, inactive
There seem to be two rulesets i can load (active and inactive) ...
.. but where are these stored?
I can't find their location as active/inactive are pretty bad search terms and dpkg-query -L iptables doesn't help either.
As i'm provisioning my servers with puppet/chef it would be nice to know wether there is some place i can put my rulesets and add a simple shell script to /etc/networking/if-pre-up to load these.
Then i could ommit the iptables-persistent package which ain't that flexible as it doesn't allow loading different rulesets.
Thanks for your help.
iptables stores the rules in memory but the ruleset created by iptables-save ruleset-name can be found in the file
/var/lib/iptables/ruleset-name
These can be restored by invoking iptables-restore <ruleset-name>.
I can only confirm this for Ubuntu 12.04.03 LTS - maybe this location has changed in later versions of the iptables-package.
I think something like /etc/iptables/rulesets.d would have been a more logical place to store these.
The save-path is configured in /etc/init.d/iptables at line 27 and afterwards used by initd_save() which invokes initd_counters().
libdir=/var/lib/iptables
initd_counters () {
 if test "${enable_save_counters:-false}" = true; then
    echo -n " with counters"
    $iptables_save -c > "$ruleset"
  else
    $iptables_save | sed '/^:/s@\[[0-9]\{1,\}:[0-9]\{1,\}\]@[0:0]@g' > "$ruleset"
  fi
initd_save () {
  rm -f $autosave
  ruleset="${libdir}/$@"
  echo -n "Saving iptables ruleset: save \"$@\""
  initd_counters
  echo "."
