I have a Huawei E303 modem given by a Mobile Broadband Service Provider. I did Pay for it.
I had terminated the service from that service provider. But I cannot use that modem which I did pay to gain because it has been Locked !
Is there an Application in Ubuntu for getting Unlock it ?
Is this having a legal issue ? (If so I will remove this question)
I followed certain guides on certain sites but could not fix this.
Here is the lsusb output. Last one is the particular modem :
lsusb
Bus 001 Device 002: ID 8087:0020 Intel Corp. Integrated Rate Matching Hub
Bus 002 Device 002: ID 8087:0020 Intel Corp. Integrated Rate Matching Hub
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 004: ID 10f1:1a34 Importek
Bus 002 Device 012: ID 12d1:1001 Huawei Technologies Co., Ltd. E169/E620/E800 HSDPA Modem
Bus 002 Device 013: ID 12d1:14fe Huawei Technologies Co., Ltd.
ThunderBird
  • 1,963
  • 13
  • 22
  • 31
try Linux Huawei Unlocker
Linux Huawei Unlocker is a tool that attempts to automatically remove the carrier lock on Huawei mobile broadband modems from the Linux command line. It automatically finds IMEIs, calculates unlock codes, checks SIM lock status, displays remaining unlock attempts, and asks the user for confirmation before trying the unlock code.
Prasad RD
  • 2,043
First install the Mobile partner Linux software. You can download the installation file from here.
Go to the file folder through terminal. Then enter:
sudo chmod +X install
./install
Connect the dongle with a "Foreign" SIM.
Then there will be a message to enter the Unlock Code.
Then visit the huaweicodecalculator.com and get the unlock code with entering the IMEI number of your Dongle.
** For Huawei E303 you need to get the Unlock Code with New Algorithum.
Then copy the Unlock Code and Paste it on the Mobile Partner message box and Press Unlock.
This will unock the Dongle.
here is the site, which describes how to unlock usb modem in linux:
https://girobiro.wordpress.com/2012/03/08/unlock-3g-usb-dongles-in-linux/
Rashi
  • 135
