The title may sound silly, but on Ubuntu 13.10, I'm getting frequent audible notifications using text to speech.
Is this the "speech dispatcher" and how can I disable it?
Pressing AltSuperS will disable or enable speech dispatcher.
The last thing you should hear is "screen reader off" :-
ps. The Super key is the "windows" key...
Go to the Settings application. Select Universal Access. You will see a tab labeled "Seeing". In there should be Screen Reader. Turn that off.
I had the same problem maybe, starting with Ubuntu 15.04. The Screen reader is off, same with the dispatcher setting; but it keeps telling me what I'm typing.
I have running four dispatcher, all at the time that can't be killed because they're starting again directly. To solve my problem, I went to System Settings -> Sound. On Applications, I muted the four speech-dispatcher.
Do you want to change the systemwide settings for Speech Dispatcher? The (yes/no) systemwide settings for Speech Dispatcher can be changed by editing the /etc/default/speech-dispatcher file.
Open the terminal and from the terminal open the /etc/default/speech-dispatcher file for editing in nano text editor:
sudo nano '/etc/default/speech-dispatcher'
Find the lines in speech-dispatcher that say:
# Set to yes to start system wide Speech Dispatcher
RUN=yes
...and change RUN=yes to RUN=no.
This will disable the system wide speech dispatcher audible notifications, if they have been previously enabled. Press the keyboard combination Ctrl+O and after that press Enter to save the speech-dispatcher file. Press the keyboard combination Ctrl+X to exit nano.
You can still toggle enable/disable the screen reader after it has been turned off systemwide by using the keyboard shortcut Alt+Super+S
Maybe "orca" has bean launched. Kill the "orca" (Screen Reader) process, then you should hear "screen reader off".
I was also facing same problem with Laptop My solution was simple System -> Sound -> Application and then I muted all four Speech-dispatcher and it solves my issue.
You can disable it in following ways :-
Press Alt + Super + S
or goto System Settings > Universal Access > Turn Off Screen Reader
If you will check your System Setting > Sound > Applications then may be you can find that some instance of Speech Dispatcher is running. You can kill the running instances in this way:-
deepak@SpiritualDixit-PC:~$ ps aux | grep speech
deepak 2593 0.0 0.0 289004 5076 ? Sl 10:10 0:00 /usr/lib/speech-dispatcher-modules/sd_dummy /etc/speech-dispatcher/modules/dummy.conf
deepak 2599 0.0 0.0 289004 5008 ? Sl 10:10 0:00 /usr/lib/speech-dispatcher-modules/sd_cicero /etc/speech-dispatcher/modules/cicero.conf
deepak 2603 0.1 0.1 531004 9608 ? Sl 10:10 0:03 /usr/lib/speech-dispatcher-modules/sd_espeak /etc/speech-dispatcher/modules/espeak.conf
deepak 2632 0.0 0.0 289016 5024 ? Sl 10:10 0:00 /usr/lib/speech-dispatcher-modules/sd_generic /etc/speech-dispatcher/modules/generic.conf
deepak 2635 0.0 0.0 104284 2320 ? Ssl 10:10 0:00 /usr/bin/speech-dispatcher --spawn --socket-path /run/user/1000/speech-dispatcher/speechd.sock --port 6560 --communication-method unix_socket
deepak 4708 0.0 0.0 21292 944 pts/9 S+ 11:05 0:00 grep --color=auto speech
deepak@SpiritualDixit-PC:~$ kill 2593
deepak@SpiritualDixit-PC:~$ kill 2599
deepak@SpiritualDixit-PC:~$ kill 2603
deepak@SpiritualDixit-PC:~$ kill 2632
deepak@SpiritualDixit-PC:~$ kill 2635
deepak 4719 0.0 0.0 21292 944 pts/9 S+ 11:06 0:00 grep --color=auto speech
On my Debian 12 as root
apt remove orca
did the trick.
It probably works the same in Ubuntu.
