Troubleshooting with apache Tomcat 7 steps should be followed ....
after downloading apache-Tomcat 7 // open terminal go to that downloading file folder in which tar.gz file is still.
Untar the tar file
tar -xzvf filename.tar.gzmove a extracted directory of apache-Tomcat7 in current path
sudo mv Directory_Name(Extracted eg.apache-Tomcat 7.0.32) /usr/local/Tomcat7
to set environment variable for Tomcat7
sudo nano /usr/local/Tomcat7/bin/setenv.sh
then Nano editor will open ..
JAVA_HOME =/usr/lib/jvm/java-6-sun
export CATALINA_OPTS="$CATALINA_OPTS -Xms128m -Xmx1024m -XX:MaxPermSize=256m
after hit ctrl+X to save file
- to set the role and username and password.
sudo nano /usr/local/Tomcat7/conf/./tomcat-users.xml
<role rolename="manager-gui" />
<role rolename="manager-script" />
<role rolename="manager-jmx" />
<role rolename="manager-status" />
<user username="admin" password="admin" roles="manager-gui,manager-script,manager-jmx,manager-status"/>
Ctrl+X to save file
- If Port no confliction comes in a way then open file to change the port no.
sudo nano /usr/local/Tomcat7/conf/./server.xml
then change the connector port as you want....
