I have a PXE server at home for doing network-based installs, which uses the text-based alternate installer.
However in 10.10 the Ubiquity (aka graphical) installer has some really nice features; like installing in the background while I fill out my user information, installing updates as part of the install, and it looks pretty great.
Is there a way to set up netboot with ubiquity so I can use my existing PXE server but have a nice graphical installation?
Jorge Castro
  • 73,717
The trick is to load a minimal system with NFS-Support. This system can start the graphical installer. This hotwo should help setting this up.
If you like experimenting around with pxe I recommend fog, this has alot of features and will setup part of the installation by itself. It will also allow you to backup partitions over network and load them back.
sBlatt
  • 4,619
You need to export the live filesystem over NFS, and set the NETBOOT and NFSROOT kernel command line parameters.
See this help document (under "A variation") for the full details.
Evan
  • 5,068
