I am running on ubuntu 12.04 (64bit).
I bought a wacom intuos tablet CTH-480S.
It seems recognized when prompted lsusb , 'ID 056a: 0302 Wacom Co., Ltd.' appears.
But it does not work.
Manager settings for wacom tablet is installed, but does not detect tablet.
Thank you for your help, I do not know where to start.
Sébastien
Sduth
  • 13
The following approach works for me on Ubuntu 13.04 and 13.10:
  • Download input-wacom-0.20.0.tar.bz2 from SourceForge
  • Untar it and run ./configure. It is necessary to have gcc installed to compile (sudo apt-get install gcc)
  • Copy 3.7/wacom.ko to /lib/modules/$(uname -r)/kernel/drivers/input/tablet/
  • Add wacom to /etc/modules because tablet is not recognized automatically and the module is not loaded without this.
The above worked fine for kernels 3.8.0.34 on Ubuntu 13.04 and mainline 3.12.6 on Ubuntu 13.10. I've installed 3.12.6 to check if its wacom driver contains recent changes but it is not the case.
Zanna
  • 72,312
The Linux Wacom folks are working on getting the new Intuos tablets to work right out of the box (the cth and ctl models).
If you feel confident with patching, you can get your tablet to work early - read more on the Linux Wacom Mailing List.
begtognen
  • 1,690
I saw this comment on this site. It seems that it is resolution for my tablet, but I do not know what to make with files input-wacom-0.20.0 mention in this announcement? Somebody could help me? Thank you.
[http://sourceforge.net/mailarchive/forum.php?forum_name=linuxwacom-announce&max_rows=25&style=nested&viewmonth=201312][1]
Its here! After an unexpectedly long wait for the patches to get accepted upstream, input-wacom now offers backported support for the three new "Intuos" tablets recently released by Wacom. If your new tablet has been sitting idle for the past few weeks, now's your chance to start using it :) Grab a tarball and give it a whirl!
Jason Gerecke (1): input-wacom 0.20.0
Ping Cheng (5): Backport Bamboo One to 2.6.30 Not all multi-interface devices support touch Scale up touch width and height values for Intuos Pro Make sure touch_max is set for touch devices Add support for three new Intuos devices
git tag: input-wacom-0.20.0
http://sourceforge.net/projects/linuxwacom/files/xf86-input-wacom/input-wacom/input-wacom-0.20.0.tar.bz2/download MD5: 86ec5c2a0a743889af6fa2e72b838f76 input-wacom-0.20.0.tar.bz2 SHA1: d2a54d73dbd45152a7f622ec01e1f124e85792a8 input-wacom-0.20.0.tar.bz2
Sduth
  • 13
I am using 3.11.0-15-generic
  1. I got this working using this already posted link.
  2. When it sends you off to download the latest release I only got this working with input-wacom-0.20.0 NOT xf86-input-wacom-0.22.1.
  3. For the section 'Build / Install' I replaced 'kernel version' with '3.7' as the release did not have a version for my build (mentioned above).
  4. For to the section called 'Module Loading' I chose to run the commands instead of restarting. The 2nd and the 3rd commands throw up errors, but ignore them and continue.
  5. Open up 'Wacom Tablet' in 'System Settings' and you will see that your device has been recognized.
