I wanted Crontab shut down the system daily but it didn't do so, did I misspelled something? This is my Crontab file:
 /etc/crontab: system-wide crontab
 Unlike any other crontab you don't have to run the `crontab'
 command to install the new version when you edit this file
 and files in /etc/cron.d. These files also have username fields,
 that none of the other crontabs do.
SHELL=/bin/sh
PATH=/usr/local/sbin:/usr/local/bin:/sbin:/bin:/usr/sbin:/usr/bin
 m h dom mon dow user   command
17 *    * * *   root    cd / && run-parts --report /etc/cron.hourly
25 6    * * *   root    test -x /usr/sbin/anacron || ( cd / && run-parts --report /etc/cron.daily )
47 6    * * 7   root    test -x /usr/sbin/anacron || ( cd / && run-parts --report /etc/cron.weekly )
52 6    1 * *   root    test -x /usr/sbin/anacron || ( cd / && run-parts --report /etc/cron.monthly )
Shutdown every day at 02:30 am
30 0 2 * * * /sbin/shutdown -h now
It's ok but I'm a bit new to Ubuntu, so I do open Crontab -e in the Terminal an it's looks like this:
# Edit this file to introduce tasks to be run by cron.
# Each task to run has to be defined through a single line indicating with
# different fields when the task will be run and what command to run for the
# task. To define the time you can provide concrete values for minute (m),
# hour (h), day of month (dom), month (mon), and day of week (dow) or use
# '*' in these fields (for 'any').
# Notice that tasks will be started based on the cron's system daemon's
# notion of time and timezones. Output of the crontab jobs (including
# errors) is sent through email to the user the crontab file belongs to
# (unless redirected).
# For example, you can run a backup of all your user accounts at 5 a.m
# every week with:
# 0 5 * * 1 tar -zcf /var/backups/home.tgz /home/
# For more information see the manual pages of crontab(5) and cron(8)
# m h dom mon dow command
30 02 * /sbin/shutdown -h now
So I should type my command at the end or how? and how to save it because I'm confused.
MarAvFe
  • 105
You have configured the crontab wrong do as following:
  1. In terminal type:
    sudo crontab -e
  2. Then give the entry for it like:
    30 02 * * * /sbin/shutdown -h now
David Foerster
  • 36,890
  • 56
  • 97
  • 151
Tarun
  • 4,275
  • 15
  • 53
  • 74
Trying /sbin/poweroff just didn't make it happen. What worked for me was
$ sudo crontab -e
and then
30 2 * * * sudo poweroff
MarAvFe
  • 105
I operate in the following manner.
echo 'hoge ALL=NOPASSWD: /sbin/shutdown' | sudo tee /etc/sudoers.d/hoge
crontab -e
26 4 * * * sudo shutdown -r now
yuuta
