10
I'm working in Ubuntu 10.10 and am trying to start a single node cluster in Hadoop.
hadoop@abraham-Dimension-3000:/usr/local/hadoop$ bin/start-all.sh
mkdir: cannot create directory `/usr/local/hadoop/bin/../logs': Permission denied
starting namenode, logging to /usr/local/hadoop/bin/../logs/hadoop-hadoop-namenode-abraham-Dimension-3000.out
/usr/local/hadoop/bin/hadoop-daemon.sh: line 117: /usr/local/hadoop/bin/../logs/hadoop-hadoop-namenode-abraham-Dimension-3000.out: No such file or directory
head: cannot open `/usr/local/hadoop/bin/../logs/hadoop-hadoop-namenode-abraham-Dimension-3000.out' for reading: No such file or directory
localhost: mkdir: cannot create directory `/usr/local/hadoop/bin/../logs': Permission denied
localhost: starting datanode, logging to /usr/local/hadoop/bin/../logs/hadoop-hadoop-datanode-abraham-Dimension-3000.out
localhost: /usr/local/hadoop/bin/hadoop-daemon.sh: line 117: /usr/local/hadoop/bin/../logs/hadoop-hadoop-datanode-abraham-Dimension-3000.out: No such file or directory
localhost: head: cannot open `/usr/local/hadoop/bin/../logs/hadoop-hadoop-datanode-abraham-Dimension-3000.out' for reading: No such file or directory
localhost: starting secondarynamenode, logging to /usr/local/hadoop/bin/../logs/hadoop-hadoop-secondarynamenode-abraham-Dimension-3000.out
localhost: /usr/local/hadoop/bin/hadoop-daemon.sh: line 117: /usr/local/hadoop/bin/../logs/hadoop-hadoop-secondarynamenode-abraham-Dimension-3000.out: No such file or directory
localhost: head: cannot open `/usr/local/hadoop/bin/../logs/hadoop-hadoop-secondarynamenode-abraham-Dimension-3000.out' for reading: No such file or directory
starting jobtracker, logging to /usr/local/hadoop/bin/../logs/hadoop-hadoop-jobtracker-abraham-Dimension-3000.out
/usr/local/hadoop/bin/hadoop-daemon.sh: line 117: /usr/local/hadoop/bin/../logs/hadoop-hadoop-jobtracker-abraham-Dimension-3000.out: No such file or directory
head: cannot open `/usr/local/hadoop/bin/../logs/hadoop-hadoop-jobtracker-abraham-Dimension-3000.out' for reading: No such file or directory
localhost: starting tasktracker, logging to /usr/local/hadoop/bin/../logs/hadoop-hadoop-tasktracker-abraham-Dimension-3000.out
localhost: /usr/local/hadoop/bin/hadoop-daemon.sh: line 117: /usr/local/hadoop/bin/../logs/hadoop-hadoop-tasktracker-abraham-Dimension-3000.out: No such file or directory
localhost: head: cannot open `/usr/local/hadoop/bin/../logs/hadoop-hadoop-tasktracker-abraham-Dimension-3000.out' for reading: No such file or directory
I have no clue what I'm doing wrong or what some of these errors suggest.
hadoop@abraham-Dimension-3000:/usr/local/hadoop$ jps
5099 Jps
Can anyone with diagnosing the problem.
Jorge Castro
  • 73,717
ATMathew
  • 1,266
The errors suggest a permissions problem.
Make sure that the hadoop user has the proper privileges to /usr/local/hadoop. Try:
sudo chown -R hadoop /usr/local/hadoop/
green
  • 14,406
Mark Russell
  • 7,396
you specified the working directory for hadoop file system with other than the hadoop user, so set the directory which has read, write permissions to hadoop user or change the ower of the directory
Try ::
sudo chown -R hadoop-user /user/hadoop_project/
or
sudo chmod 777 /user/hadoop_project
where 'hadoop-user' login name for hadoop envirnoment . 'hadoop-project' specified working directory for hadoop file system. (specify your own login and directory that you are using for hadoop installation)
Jorge Castro
  • 73,717
