I am using Nemo on Unity. Nemo is not generating thumbnails in 12.04 but Nautilus does it so well. Why can't Nemo do itself independently?
Seth
  • 59,332
Huseyin
  • 802
In case there's still anyone using nemo on Ubuntu 12.04 (or Linux Mint 13) I've encountered the same issue.
The problem is explained here and seems to be a bug in this particular version of nemo.
As a temporary solution, you can remove the ~/.thumbnails directory and replace it with a symlink to ~/.cache/thumbnails
To do this, run the following 2 commands in the terminal:
rm -r ~/.thumbnails
ln -s ~/.cache/thumbnails ~/.thumbnails
Some in the linked post above have reported side effects like compounding thumbnails in the ~/.cache/thumbnails directory due to the symlink, but I haven't had any issue. My guess is they were switching between using both nemo and nautilus which wrote to both directories.
