65
I want to use my flashdrive in Windows XP, which I am currently running in Virtualbox, but when I open up the settings to enable usb usage, I get an error:
Failed to access the USB subsystem.
VirtualBox is not currently allowed to access USB devices.
You can change this by adding your user to the 'vboxusers' group.
Please see the user manual for a more detailed explanation
Result Code: NS_ERROR_FAILURE (0x00004005) Component: Host Interface: IHost {30678943-32df-4830-b413-931b25ac86a0} Callee: IMachine {22781af3-1c96-4126-9edf-67a020e0e858}
Does anyone know how to fix this!?
Zanna
  • 72,312
6 Answers6
95
In your host, run this command:
sudo usermod -a -G vboxusers $USER
Now perform a logout (always required after add current user to a group).
After login, check that you are in the vboxusers group with this command, make sure that vboxusers is in the shown list:
groups $USER
kiri
  • 28,986
20
This works for me and my problem with VirtualBox was solved
sudo usermod -a -G vboxsf "$USER"
Zanna
  • 72,312
Serjik
  • 398
  1. In a terminal run:
    sudo adduser $USER vboxusers
  2. Reboot all systems.
Zanna
  • 72,312
  1. Add the user as suggested by other answer using usermod command.
  2. Run the command id. You should see vboxusers in the list.
  3. If you don't see that, you may restart your computer and try id again.
When you get vboxusers listed as a result of running id, you're good to use USB with virtual box.
Aaron Hill
  • 5,035
Shakus
  • 191
id <username>
That will give you
uid=1000([username]) gid=1000([username]) groups=1000([username]),10(wheel),18(dialout),497(plugdev)
if vboxusers is missing in that then add it
sudo usermod -a -G vboxusers [username]
This should resolve the issue
Zanna
  • 72,312
Would like to mentionn for those who no solution work like me, ensure you are part of the group vboxusers, if it does not exist, addgroup vboxusers.... after, delete in the host usb settings all the usb filters (devices) you have... reboot the guest In the host, use empty filters to recreate manually your devices, put any name just copy the two following fields from the original filter still available, restart your virtual guest.... voila, your devices are there ... its the only way i found to force them out of at least ten other solutions.. Enjoy
