I am trying to install Emacs 24 on Ubuntu 12.04 from the PPA as follows
sudo add-apt-repository ppa:cassou/emacs
sudo apt-get update
sudo apt-get install emacs24 emacs24-el emacs24-common-non-dfsg
My system is already running Emacs 23.3.1 from the default repositories. The install runs normally before erroring out with the following message.
install/ilisp: Handling install for emacsen flavor emacs24
emacs-install: /usr/lib/emacsen-common/packages/install/ilisp emacs24 emacs23 failed at /usr/lib/emacsen-common/emacs-install line 28, <TSORT> line 20.
dpkg: error processing emacs24 (--configure):
subprocess installed post-installation script returned error exit status 255
 emacs24
I came across this thread which also discusses a broken Emacs 24 installation but their problem was of missing files, which mine does not seem to be. I have also made sure that the dependencies are there by running
sudo apt-get install build-essential
sudo apt-get build-dep emacs
This thread from last year about 11.10 recommends removing all of emacs first but that sounds pretty extreme, and as one commenter there pointed out, purging emacs from 12.04 may remove some Ubuntu components as well. I am hoping there are some better solutions out there by now.
wsaleem
  • 333
It seems like you have a package (ilisp) in your distribution that is having problems upgrading, and that makes the whole upgrade to fail. Every file in your directory /usr/lib/emacsen-common/packages/install will be executed with emacs versions (new and old) as arguments as part of the upgrade process. If one of them fails, the upgrade will fail.
You have two options here:
  1. Debug the script ilisp at that location, find out why fails and workaround it.
  2. Remove the script (or store it somewhere else) so that the upgrade does not fail. This is the easiest solution, but a little risky (you always can take a look to the script to know what you would be missing).
juanleon
  • 128
