14
I have a laptop on which I have installed Ubuntu 12.04 and Windows Now just for learning purposes I am going to install Backtrack OS on it.
My laptop has 4 GB of RAM so according to the recommendation I have allocated 8 GB of swap space on my hard drive.
can I share the swap space between these two OS (Backtrack and Ubuntu)
I really don't want to waste 8 GB of more space for swap (because as I have noticed it is rarely used and as far as I know OS doesn't store any data in swap space, does it?) So is there a way with which I can share this 8 GB swap partition? If yes how?
Braiam
  • 69,112
Null pointer
  • 2,607
Yes, you can share swap area with two or more operating systems. To share swap area, create the swap area when you install the first operating system and then when you install the second one, do not create a new swap area, instead just use the first OS's swap area as the mount point for swap area of the second OS.
If you have already installed both OS's, use gparted to create a common swap area and then add it to your /etc/fstab file to automount it at boot-time.
Just in case you would like to know the drawbacks of using a shared swap area, refer this question on StackExchange:
jobin
  • 28,567
Yes, it's possible. The swap is only used while the system is running, so you can do what you want with the swap space when it isn't running, such as use it as swap space for another Linux installation. You can even share swap space between Linux and Windows, but it's a bit more work.
There is one exception: if you want to hibernate, then the swap space is in use while the system is hibernating.
If you point the installer at the existing swap space during the installation of the second distribution, it will be able to make use of it.
With today's disk sizes, there is usually no point in saving a couple of GB with such tricks. But it's possible.
However, I question the utility in installing two Linux distributions in dual boot. Dual boot sucks — you can't run the two operating systems at the same time. If you want to run programs from two different Ubuntu releases, or more generally from two Linux distributions, I recommend a different approach: pick the one that has the most recent kernel and use it as your main operating system. Install the second one and run programs from it directly from your installed system, using schroot. I've written a guide on doing this which covers the installation of the second system using debootstrap and the schroot setup.
