I'm trying to install Ubuntu Server 13.10 AMD64 x86 (The guest) on my TOSHIBA Satellite L655D-S5109 (The host).
My/the processor is AMD Turion IIP540 Dual-Core Processor 2.40GHz (64bit OS/x86) And I'm using VirtualBox 4.3.2 r90405
The problem i found is the common "this kernel requires an x86-64 cpu but only detected an i686 cpu".
Reaing on other posts in here and Stackoverflow and some other places i found out that i need the x86 virtualization (Wikipedia)
Checking the Oracle VM VirtualBox on the VM System tab, i found that I DO have the VT-x/AMD-V ON or activated or the checkbox checked... but i still can't install Ubuntu Server, the message still appears... what else is there to do?
Should i giveup and install a 32bit? Should the virtualization be enables on my computer (Host) BIOS or what else is there to check/verify?
