I'm new to Ubuntu and trying to figure out if it's possible to have a remote access using ssh keys on a 3g dongle? Is there any possible way? Maybe using a 3g wireless router? How to set-up? Can I access Dynamic IP address? Sorry got a lot of questions this is for my project. I hope you guys can help or sort it out. :)
Asked
Active
Viewed 3,968 times
Yeah it's possible to have remote access using a 3g dongle. To get started, open up the terminal on the machine you want to remotely access and type ifconfig and note the ip address under the pppoe section. This will be the ip address of your machine on the internet. Then you can just ssh user@ip_address from your other machine and you're good to go.
However there are some problems with this method.
- Your ip address might change every time you reconnect the dongle since it uses dhcp to get its ip address from its server. So you might have to perform
ifconfigevery time which defeats the entire point of remote access. - Since your dongle probably doesn't use NAT, all your open ports are exposed to the internet which could be potentially dangerous. I'd suggest you use iptables or some other firewall to close up the ports which are not required.
sayantankhan
- 1,701
