When I am using the command make menuconfig, then its showing
sharath@sharath:~/openwrt$ make menuconfig
Checking 'working-make'... ok.
Checking 'case-sensitive-fs'... ok.
Checking 'getopt'... ok.
Checking 'fileutils'... ok.
Checking 'working-gcc'... ok.
Checking 'working-g++'... failed.
Checking 'ncurses'... failed.
Checking 'zlib'... failed.
Checking 'gawk'... failed.
Checking 'flex'... failed.
Checking 'unzip'... ok.
Checking 'bzip2'... ok.
Checking 'patch'... ok.
Checking 'perl'... ok.
Checking 'python'... ok.
Checking 'wget'... ok.
Checking 'gnutar'... ok.
Checking 'svn'... ok.
Checking 'gnu-find'... ok.
Checking 'getopt-extended'... ok.
Checking 'non-root'... ok.
Build dependency: Please install the GNU C++ Compiler (g++).
Build dependency: Please install ncurses. (Missing libncurses.so or ncurses.h)
Build dependency: Please install zlib. (Missing libz.so or zlib.h)
Build dependency: Please install GNU awk.
Build dependency: Please install flex.
Prerequisite check failed. Use FORCE=1 to override.
make: *** [tmp/.prereq-build] Error 1
How can I resolve this ?
sharath
  • 31
It fails because of missing dependencies. You need to install the following packages:
sudo apt-get install gawk zlib1g libncurses5 g++ flex
After installing these packages your command should run through.
chaos
  • 28,186
Making menuconfig is requiring You to have developer's libraries of some packets that are used by a build You want to perform.
There is one of answers: How do I install ncurses header files?
Yeah, You can be not in need of ncurses binaries, but You do need it's developer's libraries. Something alike is about the rest of dependencies.
On kubuntu 16.04LTS I had a similar issue compiling openwrt, but no package existed that satisfied the specific issue with ncurses:
The only way to fix it was to add the following repository to my sources:
sudo add-apt-repository "deb http://archive.ubuntu.com/ubuntu $(lsb_release -sc) main universe"
sudo apt-get update
sudo apt-get install libncurses5-dev
On kubuntu 16.04LTS the answer from @MoonCactus have fixed ncurses problem, It's great.
but for
you can try
aptitude install zlib1g-dev
follow the system masseges to downgrade
     Keep the following packages at their current version:
1)     zlib1g-dev [Not Installed]
Accept this solution? [Y/n/q/?] n
The following actions will resolve these dependencies:
     Downgrade the following packages:
1)     zlib1g [1:1.2.8.dfsg-2ubuntu4.1 (now) -> 1:1.2.8.dfsg-2ubuntu4 (xenial)]
Accept this solution? [Y/n/q/?] y
The following packages will be DOWNGRADED:
  zlib1g
liang
