Whenever I try and Install Flux (in terminal) and I type in "sudo apt-get update", it says:
Failed to fetch http://ppa.launchpad.net/kilian/f.lux/ubuntu/dists/saucy/main/binary-i386/Packages 404 Not Found.
There was no official flex gui for saucy.So try to install flex-gui from raring.Follow the simple steps given below to install flex-gui in ubuntu 13.10.
Run the below commands,(if you already do this,skip to the next step)
sudo add-apt-repository ppa:kilian/f.lux
sudo apt-get update
Run the below command to edit kilian-f_lux-raring.list file,
sudo gedit /etc/apt/sources.list.d/kilian-f_lux-saucy.list
And delete all the lines in that file ,add the below lines and save the file.
deb http://ppa.launchpad.net/kilian/f.lux/ubuntu raring main
# deb-src http://ppa.launchpad.net/kilian/f.lux/ubuntu raring main
Update the software repositories and then install flex-gui
sudo apt-get update
sudo apt-get install fluxgui
Did you get the links from here: http://justgetflux.com/linux.html
I noticed a set of instructions there. The ppa you have above does go 404. Maybe try the instructions on the site I linked.
Edit: I noticed this comment on the page so I think this is your issue. Check the page in the link.:
fluxgui has not been officially updated for Ubuntu 13.10 (saucy salamander) yet.
Try RedShift instead. It is in official repositories.
sudo apt-get install redshift-gtk
Setup config
cd ~/.config
wget https://raw.githubusercontent.com/reversiblean/redshift-config/master/redshift.conf
Sample Config File: https://github.com/reversiblean/redshift-config/blob/master/redshift.conf
