I recently decided to use Virtualbox to run Ubuntu, but I get the message
this kernel required an X86-64 CPU, but only detected a i686 CPU
I've already enabled virtualization in BIOS, but that doesn't seem to work. Many other solutions suggest that I should download the 32-bit version, and not the 64-bit. I'm not sure about that though, since my computer clearly says "64-bit operating system" under systems. But I might just be mistaken.
Braiam
  • 69,112
jy19
That's the only solution actually. Download the 32-bits and proceed per usual.
Ubuntu is detecting that your processor architecture is 32-bit (anything that starts with i and ends in 86 is 32-bits: i386, i486, i586, i686). If you have a 64-bit processor them make sure you have a 64-bit kernel installed:
uname -a
Linux braiam-O_I 3.8.0-32-generic #47-Ubuntu SMP Tue Oct 1 22:35:23 UTC 2013 x86_64 x86_64 x86_64 GNU/Linux
Those in bold indicates:
  1. Machine: x86_64 = 64-bits
  2. Processor: x86_64 = 64-bits
  3. Hardware platform: x86_64 = 64-bits
If some of them is 32-bits (or iX86) then you don't have an 64-bit system but 32-bits installed. You must also make sure that you installed the 64-bit version of Virtual Box.
Braiam
  • 69,112
