12
This is my first post here, and I'm pretty new to Ubuntu/Linux. I currently have no other OS except for Ubuntu 13.10. (I used to have Windows 7 until i got a new Tera-byte hard drive).
My current PC build, if any of this helps:
CPU: Intel i5 quad-core
Graphics: NVIDIA GeForce GTX 650
RAM: 8 GB
HDD: 1 TB SATA 3
Motherboard: MSi Z77 A-G41
OS: Ubuntu 13.10
So I recently installed Ubuntu 13.10 and put Steam on it, and I'm seeing that my games run a lot slower than they did when I had Windows 7. I figured it was a graphics problem, so I checked System Settings → Details → Overview. It says in "Graphics" that I have "Gallium 0.4 on NVE7" (don't really know what that is). Does this mean that Ubuntu is not using my graphics card?
In System Settings → Software & Updates → Additional Drivers, it clearly shows like this:
NVIDIA Corporation: GK107 [GeForce GTX 650] -This device is using an alternative driver
(And then it shows a list of drivers that I can switch back and forth to)
So this is a bit confusing. In Software and Updates, it clearly shows that I have my NVIDIA card installed, and that I have a driver selected for it. But in System Settings, it shows I have some Gallium 0.4 thing.
I had done a bit of research, and ended up typing command:
lspci|grep VGA
in the Terminal. It showed this in response:
VGA compatible controller: NVIDIA Corporation GK107 [GeForce GTX 650] (rev a1)
The Terminal seems to recognize my graphics card.
What it looks like to me, is that I don't have the proper driver, and I might be using my CPU's integrated graphics. When I switch around which driver I am using in that list, it still does not see my card in System Settings. Some of the drivers in the list give me some sort of OpenGL error when I try to run a game.
It might just be that my games are running slow because the game developers have not optimized it for Ubuntu that well. However, that still doesn't take away from the fact that System Settings is not showing my NVIDIA card.
TL;DR Version:
How do I know if my video card is being recognized/used? If my video card is not being used, what is the best way fix that?
Please make your answers easy to understand. I do not mind wordy responses, as long as I can follow what you're saying.
Any help would be greatly appreciated! Thanks.
user.dz
  • 49,176
  • It seems you are running free driver where Steam recommend NVIDIA proprietary driver. You can confirm using: glxinfo or more precisely:
    glxinfo | grep OpenGL
  • Myself I have bad experience with installing NVIDIA proprietary driver from Ubuntu repository. so I would prefer downloading it from NVIDIA website. Check your OS architecture 32bit or 64bit using System Monitor or by just running one of these commands:
    file /bin/ls
    uname -a
  • Drop shell using Ctrl+Alt+F6 , login
    cd to_directory_where_driver
    sudo su
    chmod +x driver_filename
    service lightdm stop
    ./driver_filename
    reboot
Read very well the installing messages as the default is not always what you want.
You should keep that driver installation file because it needed in case you want to revert or repair the installation.
user.dz
  • 49,176
Try going to 'SOFTWARE & UPDATES' check 'Additional Drivers' Tab, and install the newest Driver listed there. then reboot.
LINK
To install the latest NVidia drivers look here:
LINK 1
LINK 2
I found these articles useful, and this:
General Documentation
Steam help:
LINK 1
LINK 2
I personally do not use Steam in Unity, I found it quite system resource heavy. So I installed an alternative light weight GUI, such as Gnome, LUbuntu, XUbuntu,etc, and run Steam from there, I found it greatly improved performance.
LINK
pst007x
  • 8,210
Steps to install drivers for NVIDIA GeForce GTX 650 in Ubuntu.
Motherboard: Gigabyte GA970DS3P
Processor: AMD FX-4130 Quad-Core 3.8GHz Socket AM3+
  1. Download the drivers file from NVIDIA website
  2. Open a terminal (Ctrl+Alt+F1) and run:
    sudo apt-get install build-essential
    sudo service lightdm stop
    sudo init 3
    Change to the downloaded driver directory and run:
    sudo sh downloaded_file.run
    sudo service lightdm start
    sudo reboot
If the Ubuntu boot displays an error message at startup follow these steps to resolve a conflict of drivers:
  1. Run:
    sudo apt-add-repository ppa:ubuntu-x-swat/x-updates
    sudo apt-get update
    sudo apt-get dist-upgrade
    sudo reboot
  2. After the reboot open a terminal (Ctrl+Alt+F1) and run:
    sudo init 3
    sudo reboot
karel
  • 122,292
  • 133
  • 301
  • 332
