While installing the most recent version of the kernel, I ran out of disk space. How do I go back and delete all of the old versions of the kernel that are occupying my disk
Asked
Active
Viewed 34 times
I believe a sudo apt-get autoremove will help you with that and sudo apt-get autoclean
If you are not using something older then 12.04
Goddard
- 4,860
If those kernels are selected for manual installation (which is likely since "apt-get upgrade" doesn't install them automatically, you need to issue "apt-get install" on them manually), "apt-get autoremove" won't help.
In this case:
dpkg --get-selections linux\*
Look for installed packages belonging to the older kernel, then issue "apt-get remove" on them. For example:
apt-get remove linux-headers-3.11.0-12 linux-image-3.11.0-12-generic linux-image-extra-3.11.0-12-generic
Then issue "apt-get autoclean" to get rid of cached package files.
MegaBrutal
- 444
