35
I am trying to download flareget download manager via wget I get error
wget  http://www.flareget.com/files/flareget/debs/amd64/flareget_2.3-24_amd64(stable)_deb.tar.gz
bash: syntax error near unexpected token `('
Why is that error coming and what is the solution for that?
You should use single quotes ' or double quotes " around the URL in this case (and in general):
wget  'http://www.flareget.com/files/flareget/debs/amd64/flareget_2.3-24_amd64(stable)_deb.tar.gz'
From now, you should use this method in general when you use a string which contain parentheses as argument in a command. That is because parentheses are used for grouping by the shell such that they are not communicated in any way to a command. So, the bash shell will give you a syntax error:
$ echo some (parentheses)
$ echo 'some (parentheses)'
some (parentheses)
Radu Rădeanu
  • 174,089
  • 51
  • 332
  • 407
14
Mine had nothing to do with un-escaped brackets and everything to do with an alias already being defined with the same name as the function.
Alias in one file:
alias foo="echo do something"
Function in another:
foo() {
    # Do something else
Both of these files were sourced by my ~/.bashrc, giving me the unhelpful error message:
syntax error near unexpected token (
Zanna
  • 72,312
Andy J
  • 1,137
14
It's because of the brackets. You need to escape them like this:
wget  http://www.flareget.com/files/flareget/debs/amd64/flareget_2.3-24_amd64\(stable\)_deb.tar.gz
Now it should work.
chaos
  • 28,186
